Author Topic: Search problems  (Read 3231 times)
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
Search problems
« on: October 23, 2003, 07:55:21 pm »
Love the board....
One little problem... When I try and do searches of archives over 60 days old, it returns nothing. Don't know if thats cuz archives get pitched, or it saves bandwith, etc? I just would like the option to be able to search all the archives occasionally. Might help reduce the forum clutter too.
Also, would it be possible to make a "just show topic" on the search?  Just an Idea.
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
Vol
  • Last login:June 25, 2007, 11:02:18 am
  • Mame Kabinet II in the works!
Re:Search problems
« Reply #1 on: October 24, 2003, 08:00:10 am »
Just a tip, don't flame me if you already know:
When you click the advanced search link it clears the search edit field.  I've searched for nothing a few times because of this.
tom61
  • Last login:September 18, 2017, 12:46:56 am
Re:Search problems
« Reply #2 on: October 26, 2003, 01:39:43 pm »
Yeah, search is busted. Single word searches work best in advanced mode. The board goes back actively to 2002, so past 60 days is not the problem.
GamingGreg
  • Last login:August 05, 2018, 06:04:30 pm
Re:Search problems
« Reply #3 on: January 27, 2004, 03:36:02 pm »
Any ideas as to when we can use two or more words in a search?  Quite often I try to find something I know was discussed a couple of weeks ago, and I can't find it.  I can sometimes find it if I use a single word, but then I have to wade through a ton of stuff, and often I just can't find it.
I think that the info on this board is a "gold-mine"; it's filled with lots of good stuff.  However it just can't be "mined" sometimes.  I think people wouldn't be asking the same questions over and over again, if the info could be found easier.
Don't take me wrong, I LOVE this site.  I just wish the search worked better.
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:November 22, 2025, 12:26:51 pm
Re:Search problems
« Reply #4 on: January 27, 2004, 06:28:23 pm »
The search function is not easy to use, but I can generally find what I'm looking for.  Give me an example of what you were searcing for (multi-word) and let me toy around with it to see if I come up with good results?
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
OSCAR
    • Oscar Controls
Re:Search problems
« Reply #5 on: January 27, 2004, 08:46:39 pm »
I've found that I pretty much always have to change the drop down list from "Search -ALL- members only" to "Any poster" to find what I am looking for.  Even when I am looking for something I know I posted, sometimes it won't turn up unless I change that box.
GamingGreg
Re:Search problems
« Reply #6 on: January 29, 2004, 02:56:57 pm »
Okay, here's one example.  A couple days ago I tried searching for some info on the on light gun with the ArcadeVGA card issue.  I remember the problem being discussed a few months back, but I couldn't remember the solution.  So I went to the advanced search and typed in "lightgun arcadevga" and changed the "Max age since last post" to 300, and the clicked "search".  I came up with no results.  I tried the same thing, but this time searching only the main and monitor forums, still nothing.  I eventually found my info by doing a one word search and then wading through lots of irrelevant posts.  That post BTW, did contain both of those words.
I tried this same search just now, and I only got one result (a post I made two days ago).  I still don't see the info from a few months ago come up.  Anyway this happens to me quite often, and I find myself trying different variations of the search, just to find something.  If it's fairly recent, I tend to use the "next page" thing and use my browser's word search.
Anyway that's my plight. (BTW, I also did try using "any poster" in my above search, and it made not difference in my case.)
saint
Re:Search problems
« Reply #7 on: January 29, 2004, 07:37:12 pm »
I just did that search and got 26 hits.  Here's the parameters I used. Compare to what you used?
Search terms: "lightgun arcadevga" -- match all words
Selected: Main forum, monitor forum. -- search: all members only.
Fields to search: Subject, Message
Max age since last post: 999 days
Display how many results: 999
I got the same 26 hits with 300 days instead of 999 days.
Is it possible you put the 300 in hours instead of the days field?
Please compare how I searched, try it, and see if the post you were looking for comes up?
If that ends up being the problem I may change the search function to default to 999 days (still can change it) and delete the hours field altogether.
Thanks for testing!
--- saint
--- John St.Clair
     Project Arcade 2!
GamingGreg
Re:Search problems
« Reply #8 on: January 30, 2004, 03:05:25 pm »
Okay, when I tried it with your parameters, I got 26 hits as well.  I played with a few variations, it it appears it has something to do with the "Display how many results?" field.  If it's set to 50, I get one result, but if set to 999, I get 26 results.  If you can default, this field to 999, that could help.
Also, on the hours thing; I'm not sure anyone uses or cares about that.  Usually when I'm using the search, I'm looking for stuff older than a day.  That feature probably creates more confusion, than it helps.
saint
Re:Search problems
« Reply #9 on: January 31, 2004, 12:10:17 am »
Ah, excellent feedback!  OK, I will go tinker ...
--- John St.Clair
     Project Arcade 2!
