Author Topic: Driving Cab Completed...  (Read 12224 times)
Jollywest
  • Last login:Today at 02:36:26 am
« on: November 01, 2012, 02:29:41 pm »
Hi,
I've recently finished a Driving Cab which I have converted from a non-working Cruis'n USA Arcade Machine, Here's a vid;
Thanks for all the useful info I got from BYOAC to sort different aspects of the cab.
If you wish to read more about the project, there is a blog on the conversion here;
http://arcadecabblog.wordpress.com/
TGov
  • Last login:March 21, 2017, 02:07:54 pm
Re: Driving Cab Completed...
« Reply #1 on: November 01, 2012, 03:06:21 pm »
That is REALLY nice!  Well done.
CoryBee
  • Bopity Boopy
« Reply #2 on: November 01, 2012, 03:11:17 pm »
I second that, really well done. How does it feel to play those games standing up versus sitting down? Shifting seems to be perfect upright.  :applaud:
Jollywest
« Reply #3 on: November 01, 2012, 03:16:00 pm »
Cheers, its taken a while that's for sure.
I had a look back at my eBay feedback the other day and I bought the Cruis'n cab back in September 2011.
It was fun building it but I'm mighty glad its finished.
« Last Edit: November 01, 2012, 03:27:13 pm by Jollywest »
Jollywest
« Reply #4 on: November 01, 2012, 03:26:24 pm »
Thanks, to be honest I would of preferred a Sit-down but space wouldn't permit, as you can probably tell by the vid  ;), but I am really chuffed with the outcome, it turned out a lot better than I expected.
As for the shifter it feels very nice as does the steering, the ffb is really sweet as well .. unbelievably strong!  ;D
Well Fed Games
  • Delicious!
« Reply #5 on: November 01, 2012, 04:17:15 pm »
I think I am in process of letting my driving cab project go and this just makes me sadder... because it is awesome! I love cabs with very focused themes/game lists- Sega Racing in your case. I'm not up on the emulators you are using, but no Outrun 2 though? But I guess it does use a 2-way shifter...
Jollywest
« Reply #6 on: November 01, 2012, 05:43:06 pm »
Much appreciated, but please persevere with your project.
Until I got the cab I didn't realise how bad a state it was really in, it sat in my garage for months as I toyed with the idea and I never thought the project would even get up and running. However, doing bits little and often things eventually took shape, and its definitely been worth it in the end.
The emulators I'm using are Elsemi's Sega Model 2 Emulator and Supermodel Sega Model 3 Emulator, the links are on the Blog side bar.
As for Outrun 2, I may be adding games further down the line and Outrun 2 would be one of the first to be added, I do plan to mount up / down shifter buttons to the steering wheel as well at some point. For the time being though its down tools  ;)
« Last Edit: November 01, 2012, 06:01:18 pm by Jollywest »
« Reply #7 on: November 01, 2012, 06:16:23 pm »
I'm chuffed that you're chuffed! Great job!
Jollywest
« Reply #8 on: November 01, 2012, 06:25:23 pm »
I'm chuffed that you're chuffed that I'm chuffed! .... Oh dear this could get silly ... [EDIT] >  has got silly  :P
Seriously though, thanks.
« Reply #9 on: November 01, 2012, 08:51:38 pm »
Nice build!  What are the Sega and MAME power switches for?  Can you explain how they work?
Kudos!
D
Jollywest
« Reply #10 on: November 02, 2012, 02:52:38 am »
Kudos!
D
Cheers, the 2 plugs are on IEC (kettle) cables and run round to the back of each machine, where there is an IEC socket. This socket is wired to a surge protected multiple, and all the parts of the cab (monitor/marquee light/ speakers/PC etc...) are plugged into this. The PC is set in the bios to start on A/C return of power, so one flick of a switch and your away! :)
ABACABB
  • Last login:August 26, 2023, 12:37:07 pm
« Reply #11 on: November 02, 2012, 10:40:18 am »
Very Nice Jolly.  I am very jealous.  I am kind of in the same situation as member Well Fed Games, where I collected all of the parts to build a driving cab but have made no progress for a while and I may abandon the project.  But one thing I see in your pics has me interested.  What is this Immersion PCB?  Is it out of a PC driving wheel or is it made to interface arcade hardware?  Other builds I have seen use an amplifier between the pcb and the ffb motor to get the voltage up.  In your pics it appears that the power to the ffb motor comes directly off the pcb... Does your pcb accept 24 volts?  Curious how you did that but great job!!  :applaud:
« Reply #12 on: November 02, 2012, 10:56:11 am »
The immersion pcb is the original force feedback I/O board used in Global VR arcade games which were PC based and had Happ controls.
It connects via USB and the drivers can be found on the internet.
You can order it from Global VR, but it's expensive.
I keep an eye out, but have never seen a used one.
It does require a 24v power supply to be connected.
« Last Edit: November 02, 2012, 10:59:15 am by BadMouth »
Jollywest
« Reply #13 on: November 02, 2012, 12:17:48 pm »
Thanks, the original plan was to use a Servo Amp and hack a Logitech wheel for its pcb as you mentioned, and interface it all as Sharkfactor did in his driving cab.
I knew of the Immersion Pcb though but also knew it was expensive as BadMouth said, so this was only an option when I luckily stumbled across a used one on eBay US site for £50, which came from a Need For Speed cab.
As BadMouth also said it interfaces all quite easily via Usb, and uses a 24v 5a psu which I also got from eBay for £10, and as I said to Well Fed Games, persist with your project it really will be worth it in the end.  ;)
« Last Edit: November 02, 2012, 12:31:47 pm by Jollywest »
Well Fed Games
  • Delicious!
« Reply #14 on: November 02, 2012, 01:00:45 pm »
Yeah, my problem is the line of projects in front of the driving cab- I think I might have overreached! I may go the route of a racing chair though (not as cool by any means, but I have a ton of console wheels and racing games). Racers are still my favorite builds to see though!
Jollywest
« Reply #15 on: November 02, 2012, 02:38:38 pm »
There's nothing like a good ol' project to get the juices flowing thats for sure. Good luck with whatever you decide to do.
Next for me is a Multi-Game Shooter cab but not for a good while yet... saying that I was having a look at possible conversions on eBay the other day ;D
Garza
  • Last login:July 09, 2015, 10:53:29 am
« Reply #16 on: November 20, 2012, 03:26:08 pm »
Now that is a clean machine!! I love it!! very well done...   :applaud:
nakeworks
  • Last login:October 26, 2020, 09:49:37 pm
« Reply #17 on: November 20, 2012, 04:21:11 pm »
+1 bookmarked.  I hope there are a lot of details on your blog bc I will have to copy this soon.
Thriller baby
markc74
  • Last login:March 08, 2026, 11:25:45 am
  • Flipping out
« Reply #18 on: November 20, 2012, 06:40:05 pm »
LOVE that cab. Colour scheme and theme are perfect. Top notch finish to it too.
More info please!
rCadeGaming
  • Just call me Rob!
« Reply #19 on: November 20, 2012, 10:12:32 pm »
VERY clean!   :applaud:  I like the pedals.
Jollywest
« Reply #20 on: November 21, 2012, 04:56:18 pm »
Cheers Guys, sorry I haven't replied earlier been a bit busy.
Check out the blog linked on the first post for more info, or you can pm me or post in this thread.
Bit of an update as well > Just purchased a used Outrun 2 Up / Down Shifter with return to center which will be fitted on the left of the CP somewhere at some point, I'll have to have a jiggle the pushbuttons about me thinks to fit it in.
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #21 on: November 23, 2012, 11:56:52 am »
Very nice, I really like the colors.
The calibration screen that popped up when you first started, is that part of the software included with the immersion board?
Jollywest
« Reply #22 on: November 23, 2012, 02:00:27 pm »
Cheers, It's actually part of the HyperSpin Intro video i made along with the Seeegaaaa bit
Coru
  • Last login:March 19, 2013, 05:22:51 pm
« Reply #23 on: November 23, 2012, 03:08:33 pm »
Great job! I love the simplistic sega art. very sliiiiiiick!
mgb
  • North East, US
« Reply #24 on: November 24, 2012, 01:32:24 am »
awesome job.
the cab looks great. I love the colors you chose too. the white coin door looks great against the blue cabinet
brad808
  • Last login:May 22, 2023, 08:18:15 pm
« Reply #25 on: November 24, 2012, 11:25:46 am »
Looks awesome man, very clean looking  8)
Jollywest
« Reply #26 on: January 04, 2026, 07:38:31 am »
Been a while, so here is a 14 year update;  :lol
YouTube Video
The Arcade monitor went pop, so I changed it over to an LED one due to availability & reliability.
New PC, which now just runs modern Teknoparrot racers.
New Amp and Subwoofer.
New control panel overlays.
Full repaint.
It still uses the original Happ Active steering assembly and the Immersion Touchsense FFB PCB.
« Last Edit: January 04, 2026, 07:58:42 am by Jollywest »
  • Last login:Yesterday at 08:11:32 pm
« Reply #27 on: January 04, 2026, 12:33:40 pm »
That looks great.  Did you intentionally wear a matching tracksuit to the cabinet colors?  If so, I admire that level of dedication.  If not, say you did anyway.
Jollywest
« Reply #28 on: January 04, 2026, 01:18:00 pm »
 :laugh2: yea completely intentional 🤥 🤣
