Author Topic: Best LCD monitor for ORIGINAL XBOX  (Read 26135 times)
rablack97
Re: Best LCD monitor for ORIGINAL XBOX
« Reply #40 on: November 19, 2012, 04:35:10 pm »
My xbox bartop booting up....video converter box....no flubber.....33 sec bootup...
Dell Monitor Ultrasharp...
The hard pop is the relay turning on, it's connected to the amp and monitor...
There is a smaller relay delaying the power to the video converter.
« Last Edit: November 19, 2012, 04:40:48 pm by rablack97 »
kuchta
  • Last login:February 03, 2026, 01:34:30 pm
« Reply #41 on: November 19, 2012, 05:11:43 pm »
Although, let's make sure we are on the same page.  The DVD rom trick works on a softmodded only xbox.  When you add frosty's vga softmod then it doesn't work anymore.
10-4
You will also be interested in this, if you use frosty's vga hack.  It switches the vga mode to the power button.
http://forums.xbox-scene.com/index.php?showtopic=742689&pid=4865456&mode=threaded&show=&st=&#entry4865456
As far as i know SOG doesn't matter with this converter box.
I had not seen this. If I end up using Frosty's VGA hack, I'll definitely be doing this. Thanks for pointing it out!
Also, loving the clean boot!
