Main > Project Announcements
Banana Royale (Pac Man Battle Royale Redesign Contest)
Pages: << < (36/62) > >>
Sjaak:
--- Quote from: Le Chuck on January 27, 2014, 02:50:17 pm ---For the blink do you need each pose to have a blink frame - how are you handling that?  If so it's too easy for me to make blink frames for all of them and have it look fairly uniform.  Probably the easiest for me actually but I'll build to your needs.  Also, for now, can we just use the regular small players in place of the scared frames?  If so that's easy too, just need to know where I need to copy them too on the sheet. There won't be enough space on the current sheet for everything so I can either rearrange it in a way that makes sense to me or you do it how you program against it and I'll comply.  Either or.
I'm going to work on a different way to handle the sprites. Probably reorganize the spritesheet, because now the game won't work anymore with simpler pacman-ish graphics.
Le Chuck:
Just ran it, I'll lose the lightening and the glow on Frank.  Right now the small character movements looks good, the monster movements look odd.  I can either add more frames of animation for them or is it possible to have the frames sampled twice to slow down their animation a bit, that could help too.
I can tween the image between each state *I think* effectively adding two extra frames of animation for each direction which could smooth transitions out a lot.  Thoughts?
Le Chuck:
Added some flashies but based on guidance from Sjaak will modify to fit needs.  Also included the psd I'm working from - most characters are saved in sep files so this is a lot of collapsed layers that are easier to work with a move things about on if it makes it easier for Sjaak to do a rearrange as necessary.
Generic Eric:
--- Quote ---The only real flaw in the game is if you play alone. The game throws in a CPU player that is very, very easy to beat. But luckily, people would always be playing this game, so you may not need to worry!
Sjaak, does your Banana Royale suffer from this critique?
Sjaak:
--- Quote from: Generic Eric on February 04, 2014, 01:29:36 pm ---
Nope, it throws in 3 cpu players instead of one and they are pretty hard to beat. Try it for yourself, there is a download link a couple of posts up.
Go to full version
