Main > Project Announcements
Banana Royale (Pac Man Battle Royale Redesign Contest)
Felsir:
Great stuff, Le Chuck!
Le Chuck:
The Mummy queen turned out a lot less mummy and a lot more queen. At this scale I just couldn't pull off a full body wrap and get the look I wanted. I may go back and do the black gloves in wrap but that would take a few hours just for a small detail. I have a bunch of little bugs done up that I'll have scurrying about her feet but this is a good start. Still need to finish up the Vampiress backside but I haven't been motivated on that and wanted to get the Pharaohess done.
Edit: Didn't want to back to back post for no good reason, how are we handling the scared versions of Isis and the gang? I don't know that we actually need scared versions, I think it might be overkill. I'd like to see the set in action before going in for 48 more sprites.
Le Chuck:
Ugggh. I kinda had to force this last set, not 100% happy with it but I think they're passable. I'll want to see how jarring it is when the vampiress turns around, if its a huge visual switch I'll go back and rework them, if it's smooth enough I'll leave it as is.
Anyway, I'm done for now. Upon further guidance I'll add more sprites but this will get us rolling in the right direction I'm sure.
Sjaak:
Updated the software, sprites are a bit of a mess now. Clowns sort of work. Players kinda work.
download
Some sprites are missing: sprites for blinking big players, blinking small players, scared small players (in all 4 directions)
Le Chuck:
--- Quote from: Sjaak on January 27, 2014, 02:34:46 pm ---Updated the software, sprites are a bit of a mess now. Clowns sort of work. Players kinda work.
download
For the blink do you need each pose to have a blink frame - how are you handling that? If so it's too easy for me to make blink frames for all of them and have it look fairly uniform. Probably the easiest for me actually but I'll build to your needs. Also, for now, can we just use the regular small players in place of the scared frames? If so that's easy too, just need to know where I need to copy them too on the sheet. There won't be enough space on the current sheet for everything so I can either rearrange it in a way that makes sense to me or you do it how you program against it and I'll comply. Either or.
