Software Support > GroovyMAME
Trying to create monitor presets for KT-2914 (Betson-Kortek) MultiSync
Calamity:
--- Quote from: RetroACTIVE on February 20, 2012, 06:37:23 pm ---Now Scramble and Galaxian are using the wrong resolution... higher res is selected:
SwitchRes v0.013: [scramble] (1) vertical (256x224@60.61)->(400x256@60.61)->(800x512@60.61)
The resolution isn't wrong (perfect x2 scaling), it's the range being used what's wrong. This is because the change we did modified the scoring for that resolution when calculated inside its original range. I'd need a log to see what's happening. Also some logs for the pacman/dspirit games will help.
I'm guessing it's going to be very difficult to create monitor presets for this monitor by the usual ways. I'm not sure if it would require some new features in GroovyMAME or it'll be just a matter of dividing the range in enough sub-ranges.
By now we're going to add a new range to try to force scramble/galaxian to pass through it (monitor_specs1), also we'd like to make pacman go to monitor_specs3:
monitor_specs0 15250-15900, 40-80, 2.187, 4.688, 6.719, 0.190, 0.191, 1.018, 0, 0, 248, 448
monitor_specs1 16000-17000, 58-80, 2.187, 4.688, 6.719, 0.190, 0.191, 1.018, 0, 0, 256, 448
monitor_specs2 18300-19000, 40-58, 8.300, 2.750, 9.000, 0.190, 0.191, 1.018, 0, 0, 280, 448
monitor_specs3 20001-29000, 40-80, 2.910, 3.000, 4.440, 0.451, 0.164, 1.048, 0, 0, 384, 576
monitor_specs4 29001-32000, 40-80, 0.636, 3.813, 1.906, 0.318, 0.064, 1.048, 0, 0, 496, 768
monitor_specs5 32001-34000, 40-80, 0.636, 3.813, 1.906, 0.020, 0.106, 0.607, 0, 0, 576, 768
monitor_specs6 34001-38000, 40-80, 1.000, 3.200, 2.200, 0.020, 0.106, 0.607, 0, 0, 600, 768
RetroACTIVE:
I will run again and get the logs for pacman and dspirit.
I will add the new changes to the monitor_specs and re run the tests and get logs from those as well.
Thanks so much for being so very helpful. Sorry this monitor and (me) for being a pain!
RetroACTIVE:
pacman and dspirit are perfect... mk is now not correct. Re-tried caveman ninja and its also well beyond the screen.
I've attached the original pacman.txt (before this last change) all others with _latest represent runs since the last update to monitor_specs
Calamity:
Hi RetroACTIVE,
I'm afraid you didn't copy the monitor_specs properly, as I can see in your logs (16000-17000 and 18300-19000 ranges are missing). Please double check it, specially the subindex part. Make sure there's no duplicated label for any monitor_specs. Fortunately it's been useful to discover the right range for the 288-lines games (pacman, dspirit).
I've done some additional changes, try the same games with these new settings:
monitor_specs0 15625-15900, 40-80, 2.187, 4.688, 6.719, 0.190, 0.191, 1.018, 0, 0, 248, 448
monitor_specs2 18300-18800, 40-58, 8.300, 2.750, 9.000, 0.190, 0.191, 1.018, 0, 0, 280, 448
monitor_specs3 18800-19000, 40-80, 2.187, 4.688, 6.719, 0.140, 0.191, 0.950, 0, 0, 320, 448
monitor_specs4 24000-29000, 40-80, 2.910, 3.000, 4.440, 0.451, 0.164, 1.048, 0, 0, 384, 576
monitor_specs5 31000-34000, 40-80, 0.636, 3.813, 1.906, 0.020, 0.106, 0.607, 0, 0, 576, 768
RetroACTIVE:
Ok thanks... I went back and fixed the error in mame.ini
Attached are the corrected logs. contra, pacman and dspirit are not quite there... all others look good
