Software Support > GroovyMAME
Trying to create monitor presets for KT-2914 (Betson-Kortek) MultiSync
Calamity:
I assume you're accepting the changes before leaving the modeline submenu, by pressing "1" (testing the mode)?
RetroACTIVE:
--- Quote from: Calamity on February 17, 2012, 06:50:15 pm ---I assume you're accepting the changes before leaving the modeline submenu, by pressing "1" (testing the mode)?
Yes I just double checked to be sure.
RetroACTIVE:
You're dealng with an idiot here ;)
Enter didn't save the changes... After I tweaked the values and backed up a screen... then I selected save. That locked the freq...
I tweaked V settings:
I tweaked H settings:
Here is where it all landed
Image is ok... looks like monitor is having a difficult time though.
Calamity:
Wow, I thought you would find the right values lowering Hfreq (removing lines), not adding them! :)
18.35 KHz is way much more than required, anyway. So what happens if you add this line?
monitor_specs1 18300-19000, 40-80, 8.300, 2.750, 9.000, 0.190, 0.191, 1.018, 0, 0, 320, 448
Test mk, loht, but also games like pacman, dspirit, contra, etc.
RetroACTIVE:
Ok... MK much better... I adjusted my monitor settings with my OSD and got it to fit just fine. loht... same as MK... real good now. :applaud:
Contra fits perfect with little OSD tweak... and others still look great! :cheers:
Pacman and dspirit don't fit well, they are not the right ratio and proportion and the bottom is far off the screen. The screen is all wavy too.
Side note...
Now Scramble and Galaxian are using the wrong resolution... higher res is selected:
SwitchRes v0.013: [scramble] (1) vertical (256x224@60.61)->(400x256@60.61)->(800x512@60.61)
But its starting to look much better overall!!!
