Software Support > GroovyMAME
Trying to create monitor presets for KT-2914 (Betson-Kortek) MultiSync
RetroACTIVE:
Here are the logs for the last set of monitor_specs changes...
I THINK YOU DID IT!!!! :applaud:
Sorry for being such a challenge :(
RetroACTIVE:
Ok I tried a couple more... see attached logs...and had some issues.
Its looking so good though... there are so many vertical and horizontal working now than I've ever had... ever!!!
I think I can adjust btime with OSD...
Calamity:
Try phoenix and tapper now:
monitor_specs0 15625-15900, 40-80, 2.187, 4.688, 6.719, 0.190, 0.191, 1.018, 0, 0, 248, 448
monitor_specs1 16000-17100, 58-80, 2.187, 4.688, 6.719, 0.190, 0.191, 1.018, 0, 0, 256, 448
monitor_specs2 18300-18800, 40-58, 8.300, 2.750, 9.000, 0.190, 0.191, 1.018, 0, 0, 280, 448
monitor_specs3 18800-19000, 40-80, 2.187, 4.688, 6.719, 0.140, 0.191, 0.950, 0, 0, 320, 448
monitor_specs4 24000-29000, 40-80, 2.910, 3.000, 4.440, 0.451, 0.164, 1.048, 0, 0, 384, 576
monitor_specs5 30000-34000, 40-80, 0.636, 3.813, 1.906, 0.020, 0.106, 0.607, 0, 0, 576, 768
monitor_specs6 34001-38000, 40-80, 1.000, 3.200, 2.200, 0.020, 0.106, 0.607, 0, 0, 600, 768
For paperboy, you need to use Arcade_OSD to center the video mode 512x384@60, and then use the values obtained as a feed back for the monitor_specs4 line, as we've done before.
RetroACTIVE:
Well now... I think we are about done here. :applaud: :cheers: :applaud:
I've not gone back and tweaked the monitor_spec4 but here are the adjustments needed to fix the geometry of 512x384@60 modeline
Thanks sooooooooo much for holding my hand throughout this. I now have my new PC up and running sufficiently! All these games look terrific! I have way better overall accuracy than I ever did.
I will be testing more... If I run into anything weird or something I can't figure I'll post here. But for now I would say you are ready to add the Betson/Kortek KT-XX14-SM monitor to the list of monitors that work with the totally awesome and most excellent GroovyMAME!!!!!
And again... :notworthy: :notworthy: :notworthy: :notworthy: :notworthy:
Calamity:
Sounds great, thanks for your perseverance too ;)
