Main > Main Forum
usb2gun seems like it has arrived --- UPDATED ---?
Pages: << < (3/9) > >>
lodoss118:
i am also assuming  when hooked up to windows it should detect it as a joystick with force feedback, so could tets it in the joystick control pannel.
lodoss118:
ok found a laptop 24v 6am power supply/charger it also has the 2 pin connector so i connect it in straight away :P now i need the guns
lodoss118:
quick update, connected usb2gun to pc via printer cable window 7 detects to gun joysticks and i have the option to calibrate them. Obviously i have no real arcade guns at the moment
all i need is to get them but finding them hard. I want to try to get the namco guns if anyone can help.
Q*Bert_OP:
--- Quote from: lodoss118 on September 11, 2011, 11:33:59 am ---quick update, connected usb2gun to pc via printer cable window 7 detects to gun joysticks and i have the option to calibrate them. Obviously i have no real arcade guns at the moment
http://na.suzohapp.com/amusement/optical/pb030314100.htm
lodoss118:
Hi guys just another quick update:
I bought some namco guns setted everything up in widnows 7, it detects them as gamepads and the crosshair moves when i move the gun,
When i shoot at the screen it register as button 1, if  i shoot off screen it register as button 2. The screen flashes when i shoot.
The only problem i have i can't seem to get the recoil/ff to work, i am just using a laptop charger 24v 6a it has adaptors on it.
So i take of the daaptor and it has a 2 pin connector which i drectly connect to the board.
Go to full version
