Main > Main Forum
usb2gun seems like it has arrived --- UPDATED ---?
lodoss118:
kinda getting confused, sorry for this not really technical about these things. So will need a separate power supply to connect to 24v pin, if so can u show me something on ebay that might work?
BadMouth:
--- Quote from: lodoss118 on September 09, 2011, 10:18:45 am ---kinda getting confused, sorry for this not really technical about these things. So will need a separate power supply to connect to 24v pin, if so can u show me something on ebay that might work?
Just type in 24V power supply. Anything 5A and up will work.
Here is the happ one:
http://na.suzohapp.com/powersupplies/80021600.htm
If you're in the U.S., order it from Divemaster in the Buy/Sell/Trade forum.
He can sell you the guns too, but they aren't cheap.
bkenobi:
Unless you are using this on an arcade board, what use is the recoil? Does MAME or any other emulator have the capability to fire the needed signal to the board to start/stop recoil/vibration? I suspect this could be done with MAMEhooker, but I've obviously never tried. Just curious.
lodoss118:
lol good point, but still want the possibility to use so want to get everything setup, well i am home but it is late so tomorrow will have a look.
Siris:
Maybe I'm mistaken but I would assume the recoil is triggered any time the trigger is pulled?
It's not like a steering wheel where feedback would only be felt in extreme turns or what not, it's a gun you fire it you should feel it!
Just my 2 cents
