Main > Main Forum
usb2gun seems like it has arrived --- UPDATED ---?
Franco B:
Where did you get the Namco guns from? I'm after some so I can buy some Point Blank PCBs.
BadMouth:
--- Quote from: lodoss118 on September 14, 2011, 01:46:30 pm ---Hi guys just another quick update:
I bought some namco guns setted everything up in widnows 7, it detects them as gamepads and the crosshair moves when i move the gun,
When i shoot at the screen it register as button 1, if i shoot off screen it register as button 2. The screen flashes when i shoot.
The only problem i have i can't seem to get the recoil/ff to work, i am just using a laptop charger 24v 6a it has adaptors on it.
So i take of the daaptor and it has a 2 pin connector which i drectly connect to the board.
It may require some kind of signal from the game.
Hopefully you can find an input somewhere that triggers it.
If you do, then you have an led-wiz or something send the signal whenever button 1 has been pressed.
If not, then you could bypass the usb2gun and have led-wiz or whatever trigger a relay or transistor that's connected to the recoil solenoid.
One of my projects that's not getting done is adding an aim-trak to a happ recoil gun.
The last transistor I tried couldn't handle the power. I picked up some beefier ones and might get a chance to try them tonight.
How about posting some pics of this stuff?
lodoss118:
will do next 2 days :P
lodoss118:
franco here:http://leisureservices.biz
lodoss118:
the strange thing is when i connect the laptop charger i can hear a weird clicking noise coming from it (the charger)?
