Author Topic: Dual 15/17 inch monitors as marquee?  (Read 2722 times)
korbitz
  • Last login:June 30, 2017, 01:09:54 pm
« on: June 11, 2011, 11:54:36 am »
Just wondering if anyone has tried this and if so any links available, if not just wondering what the cons could be, i know there will be a minor gap between them, but if decased this would be a maximum of say 1 inch, on a 26 inch width cab a small portion, ideas? thoughts?
Heres a sketchup drawing of my plans
I have decased one 17 inch and at present it would sit, 5 inches above my cab (not excessive), width wise would put it roughly 1/1.5 inches over the width of the cab, again not excessive
I was also wondering is this monitor will be good enough as my primary display
http://www.gumtree.com/p/for-sale/neovo-19-tft-1280x1024-flat-screen-monitor-with-dvi/81980051
« Last Edit: June 11, 2011, 12:02:07 pm by korbitz »
lilshawn
  • Last login:Today at 12:34:05 am
Re: Dual 15/17 inch monitors as marquee?
« Reply #1 on: June 11, 2011, 02:26:04 pm »
i would maybe display the marquee on one monitor and an instruction card or button functions on the other... i don't know if i would like a seam on my marquee
shilmover
  • Last login:September 25, 2018, 12:36:59 am
« Reply #2 on: June 13, 2011, 07:33:54 pm »
I just mounted a 24" monitor in mine...
WIll be writing a program to automagically display the correct marquee in there.
My projects...
Finished:  Stargate (only 'cause I got it that way)
In progress:  Tron, 48-in-1 for School Auction, DKJr (currently a 60-in-1), Millipede, MAME System
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #3 on: June 13, 2011, 07:41:40 pm »
I think having it would look weird because your marquee area would be larger than your primary screen.
It can and has been done.  I know Randy T used a wide screen monitor as a marquee.  Do a search on the forums to find it
shilmover
« Reply #4 on: June 13, 2011, 07:57:03 pm »
Is that for the 24" or the 2 monitors?
My projects...
Donkbaca
« Reply #5 on: June 13, 2011, 07:59:29 pm »
The two monitors.  It would look weird having dual 17 inchers for a marquee if your primary screen area is a 19 inch
korbitz
« Reply #6 on: June 14, 2011, 02:56:54 am »
Yeah, you have a point, after resizing the marquee in sketchup to match a 17 inch monitor size it does look abit overkill, will need to do some more research into this, cheers.
