Main > Project Announcements
Complete redesign due to TV failure
Pages: << < (3/6) > >>
BobA:
Use a round over bit with a radius of 1/2 of your mdf size and ride the bearing on the middle of the MDF.
IG-88:
Bob beat me too it. Tho I used some scrap to practice on first.
crashwg:
--- Quote from: BobA on July 02, 2011, 06:55:43 pm ---Use a round over bit with a radius of 1/2 of your mdf size and ride the bearing on the middle of the MDF.
After I've done one side will the bearing have a large enough place to ride?
crashwg:
TO ALL CURRENT AND FUTURE CNC OWNERS AND OPERATORS
SIMULATE!
I made the stupid mistake of not simulating the paths on the left side of the cab and the bit was cutting to the left side of a line that it was supposed to be cutting to the right side of and now I have to redo the whole piece!
What not to do:
syph007:
--- Quote from: crashwg on July 02, 2011, 06:50:38 pm ---Question: How do I emulate the look of T-Molding on 1/2" MDF with router bits?
I guess I pretty much want to "bull-nose" the edge of the MDF but I've never done that before so any guidance would be great.  I imagine I'd have to use a round over bit but what size and where to ride the bearing I'm a little confused on.
You can buy 1/2 t-molding in black or white, and colors in 5/8 (which trims up real nice to 1/2 inch) if you did want t-molding.  I just test fit a piece of 3/4 inch on 1/2 MDF and it timmed up fine too.
Go to full version
