Author Topic: New Product: Ultimarc PacLED64 LED controller  (Read 21057 times)
RetroBorg
  • Last login:September 15, 2025, 06:25:47 am
Re: New Product: Ultimarc PacLED64 LED controller
« Reply #40 on: March 24, 2012, 06:42:58 pm »
How many RGB LEDs can one PacLED64 board handle?
21
Ha, that'd be right I need 22, thanks Nephasth.
« Reply #41 on: March 24, 2012, 07:27:00 pm »
Well, if you can make this work... You can have 21 RGB LEDs and one single color LED, with one PACLED64. You might also conisder swapping out a few RGBs for single color LEDs. I have 26 RGB LEDs and 4 white LEDs (coin door lights), because of all the RGBs I bought 2 PACLED64s...
Connorsdad
  • Last login:May 18, 2024, 04:28:42 pm
« Reply #42 on: September 20, 2014, 05:33:47 am »
Im not sure what I have done apart from messed with something I shouldnt have, when my cab is switched on it used to light all the led buttons in sequence starting with white then red then green then blue then repeating. I changed something in the pacled64 software and now I dont get this animation any more. Ive no idea how to reprogram it using the pacled64 program, anyone know how to fix this?
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #43 on: September 22, 2014, 09:17:45 am »
The PacLED64 and I-PAC Ultimate I/O have the capacity to store an "attract mode" script which is enabled as soon as power is on. There is a default script which you refer to, but it sounds like you have accidentally created a new script and overwritten it.
You would need to create a new script as required using the utility.
Andy
