Main > Linux
32/64bit Groovy Arcade Linux LiveCD/Install
RobMcRaf:
--- Quote from: Calamity on January 13, 2012, 12:35:55 pm ---VeS has built an unofficial update of GroovyArcade Live-CD, including these new features:
- Automatic Wiimote setup for xorg.conf, you only need to add your system's eventX and Wiimote MACs (as explained in /etc/init.d/wiimote)
- Added the required joystick packets input-joystick event, etc.
- Cwiid already set up for guns use in MAME games.
- mame.ini already set up for Wiimote use.
- Added new command UpdateGroovyMAME, which downloads and installs the most up-to-date GroovyMAME binary from Groovy's ftp.
- GroovyMAME binary updated to version 0.144u2 (from now on you can use UpdateGroovyMAME.sh to keep your binary updated).
- OpenPPJoy included since startup, with MAME default keys already set up.
GroovyArcade2012.iso (478.8 MB - 32 bits)
www.megaupload.com/?d=4GGUPT9J
megaupload is megadown. here is a link for the GroovyMame2012
http://www.fileserve.com/file/XZUhPet/GroovyArcade2012.iso
l8r
Ansa89:
Thanks for reuploading ;D .
Ansa89:
Another interesting patch (from AGES).
It will enable very low resolutions on Xorg using ATI graphic card.
Hope to see it applied to next GroovyArcade release.
If you don't understand how to use it, just ask me.
EDIT: new patch (for xf86-video-ati 7.2.0) is here).
NightSprinter:
How do I use it? *smirks* Sadly I've been getting absolutely ZERO luck in getting any distro set up. When I tried updating GA with the latest version of portage, it refuses to do anything due to numerous masked packages and something EALP 4 or similar.
Ansa89:
Exactly, which is your problem? It could derives from a wrong configuration or from unsupported harwdare ::) .
However the patch should be applied to "xf86-video-ati" package (the name could change from distro to distro), then you have to recompile and install the new package.
PS: check your "/etc/X11/xorg.conf" and be sure that your graphic card needs the "ati" driver; if this is not your case, the patch will be useless.
