Main > Linux
32/64bit Groovy Arcade Linux LiveCD/Install
Pages: << < (63/63)
philenotfound:
I only did it on 4.1.13 but the same patches should apply on 4.1.12
You can find the patches here:
https://github.com/philenotfound/linux-stable-15khz/tree/4.1.13-15khz
Or a tarball here:
https://github.com/philenotfound/linux-stable-15khz/releases/tag/v4.1.13-15khz
DoogyRev:
How did you do it? Did you just patch the linux-3.19.diff onto your 4.1.13 kernel source or did it need tweaking?
philenotfound:
If they needed tweaking, I updated the commit message to reflect this. The linux-patch needed tweaking for 4.1. The other 2 didn't since 3.19.
Basically upon a new tag in linux-stable I create a branch <version>-15khz, cherry-pick the patches from an older one, tweak if necessary and tag them as v<version>-15khz.
On a semi-regular basis I redo this to have an up-to-date kernel on my cabinet.
DoogyRev:
Thanks, I have it working now. I needed it to use the console on my non Groovy Arcade Linux installation. I know how the offsets in the diff file work now so I should be able to sort it myself if it changes again.
Ansa89:
Now you can find updated linux kernel patches here.
Pages: << < (63/63)
Go to full version
