Main > Linux
32/64bit Groovy Arcade Linux LiveCD/Install
Pages: << < (46/63) > >>
Ansa89:
--- Quote from: ves on January 13, 2012, 09:40:29 am ---Hello Ansa, groovymame144/144u2  for Linux and Windows yes exist, look on the web.
Wow! Great news!
Can you post the link to the project (or download)? I can't find it :( .
--- Quote from: Calamity on January 13, 2012, 12:35:55 pm ---VeS has built an unofficial update of GroovyArcade Live-CD, including these new features:
- Automatic Wiimote setup for xorg.conf, you only need to add your system's eventX and Wiimote MACs (as explained in /etc/init.d/wiimote)
- Added the required joystick packets input-joystick event, etc.
- Cwiid already set up for guns use in MAME games.
- mame.ini already set up for Wiimote use.
- Added new command UpdateGroovyMAME, which downloads and installs the most up-to-date GroovyMAME binary from Groovy's ftp.
- GroovyMAME binary updated to version 0.144u2 (from now on you can use UpdateGroovyMAME.sh to keep your binary updated).
- OpenPPJoy included since startup, with MAME default keys already set up.
GroovyArcade2012.iso (478.8 MB - 32 bits)
www.megaupload.com/?d=4GGUPT9J
So the major improvements seem to be the support of wiimote and the upgrade of groovymame, right?
Calamity:
--- Quote from: Ansa89 on January 14, 2012, 04:29:33 am ---Wow! Great news!
I'm temporaly uploading updated binaries here: http://mario.groovy.org/GroovyMame/WindowsATIDrivers/
GroovyMame32x144u2Wiimote.tar.bz2
[/quote]
[/quote]
Yes, that's right. Probably next release will include AdvMenu+
torm3nt8r:
thanks for the update!!!!
Advmenu+ would be also a great update
i use advmenu with some minor problems.
sound stuttering with enabled screenshots (don't know why, but when i change sound latency in advmenu, i have no sound stuttering but scrolling to the list of games are slower - very slow)
resolution change of advmenu does only work for me when i edit xorg.conf
advmenu looks ok with my setting (320x256) - but i hope for better custom skins,....
Ansa89:
AdvanceMenu+ seems ok, but I think I will keep the standard advancemenu 2.5.0 (+ "exit_patch").
Now it's time to try to compile groovymame 0.144u2 with highscore patch :) .
One more news: recently I have fixed the driver for EMS TopGun in order to compile against linux 3.x. For more information, see the attachment.
Ansa89:
--- Quote from: Ansa89 on January 13, 2012, 08:24:00 am ---Ok, time to good news: I ported the 15KHz patch to linux 3.2.x.
Enjoy!
I made a little mistake: when apply "avga3000-3.2.diff" and then compile, you will get
--- Code: ---drivers/gpu/drm/radeon/radeon_bios.c: In function ‘radeon_get_bios’:
drivers/gpu/drm/radeon/radeon_bios.c:492:25: error: implicit declaration of function ‘MODULE_FIRMWARE’
make[4]: *** [drivers/gpu/drm/radeon/radeon_bios.o] Error 1
make[3]: *** [drivers/gpu/drm/radeon] Error 2
make[2]: *** [drivers/gpu/drm] Error 2
make[1]: *** [drivers/gpu] Error 2
make: *** [drivers] Error 2
--- End code ---
Thus because I missed the header file "linux/module.h".
This time the patch should be ok.
Go to full version
