Author Topic: 3 screen software setup  (Read 4774 times)
Smeghead
  • Better Smeg than dead
    • MY MAME BUILDS
« on: September 20, 2010, 12:02:36 pm »
Im planning on using 3 screens off some kind of card capable of running all 3, probably that Nvidia that everyone uses.
My DMD screen and the background screens are going to be mounted upside down on my cabinet for ease of installation.
Can the software rotate each screen 180? I know my Intel cards software can do it, rotate each screen individually or not.
My MAME Build:
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
Re: 3 screen software setup
« Reply #1 on: September 22, 2010, 02:04:44 am »
Why are you mounting your backglass and DMD upside down?
My experience with software rotation is that there is a performance hit.  I'd just install them correctly and not have to worry about software rotation.  Don't make things more complicated than they already are.
Smeghead
    • MY MAME BUILDS
« Reply #2 on: October 21, 2010, 11:59:45 pm »
Ive got my playfield as display 1 off my main card-1st DVI, DMD as display 4 off my main card-2nd DVI
Ive got my backglass as display 2 off my crappy PCI card
My backglass is showing up on 2 which is good but the DMD always goes to 2 and not 4 where I left it.
Can you tell Hyperpin to use 'tertiary' for backglass instead of secondary?
Why does the DMD always go to screen 2, i cant run it off that because its my crappy PCI that I only want the backglass running off
My MAME Build:
HanoiBoi
« Reply #3 on: January 01, 2011, 11:16:39 am »
I've got a related question. Some tables that I load show the DMD rotated 90 or 180 degrees.  How can I rotate them so that they are properly displayed?
This is using VP9 with Hyperpin.
Dizzle
  • Last login:August 09, 2014, 05:28:04 pm
« Reply #4 on: January 01, 2011, 12:30:49 pm »
I only have a 2 screen setup so I don't know much about the 3 screen setups, but regarding the rotation of the DMD:  go into the script of the table and search for "rol = 1".  If you change that to "rol = 0" the DMD won't rotate.
Smeghead
    • MY MAME BUILDS
« Reply #5 on: January 01, 2011, 02:17:46 pm »
yeah ive figured this out now. i make that change in the registry entry for that table though
My MAME Build:
HanoiBoi
« Reply #6 on: January 01, 2011, 06:17:23 pm »
Thanks Dizzle.  I was able to find and change the setting for Funhouse and it worked.  Another table (Star Wars) that I tried, I didn't see the setting.  Any other thoughts?
Also, where would I find this information myself?
Dizzle
« Reply #7 on: January 01, 2011, 10:36:48 pm »
HanoiBoi,
Which Star Wars table are you referring to?  I just checked my table (the Data East one released by JP not too long ago) and the rotate command was in line 76.  If it's a different version of the table, maybe search for "ror" instead of "rol".
Smeghead
    • MY MAME BUILDS
« Reply #8 on: January 02, 2011, 02:16:44 am »
Thats why you should do it in the registry, its there for all tables or you can add it
My MAME Build:
