Author Topic: Battlezone Deflection PCB  (Read 7612 times)
  • Last login:Yesterday at 07:06:54 pm
« on: February 19, 2010, 06:10:29 pm »
I just got around to pulling the deflection PCB out of my Battlezone, and I noticed that someone has done something to it.  Looks like they cut off R100 and R101 and just bridged each of those with a thick wire.
Anyone know what resistors those are supposed to be?  I'm going blind looking at a schematic...
Also... can the board be run as-is (missing R100 and R101)?
Also.  How can you tell if the bridge rectifier is bad or not?  I have a new one, regardless.
Kevin Mullins
    • Me on Myspace
Re: Battlezone Deflection PCB
« Reply #1 on: February 19, 2010, 10:57:34 pm »
Resistors removed - common field modification, it's fine.
Rectifier - standard diode test x 4
« Reply #2 on: February 20, 2010, 09:33:19 am »
How do you do a diode test?  I'm guessing just make sure current flows only one way, and not the other?
lilshawn
  • Last login:October 27, 2025, 06:16:21 pm
« Reply #3 on: February 22, 2010, 02:56:48 am »
diode test = set volt meter to diode test
sick probes on either side of diode (you may have to remove one side of diode from the board to get a good result)
should be a reading one direction - around 0.5 volts
reversing the leads should result in nothing
« Reply #4 on: February 22, 2010, 09:57:42 am »
Oh, duh.  I have a HP 34401A Multmeter.  I just now noticed the Diode test setting (it's Cont + Shift), lol.
Looks like this:
« Reply #5 on: February 26, 2010, 10:52:04 am »
Ok, so the bridge rectifier was bad (no big surprise, it kept blowing fuses).
Put the board back in, the red LED is still on (spot killer?)...
But now, I get a green dot in the middle of the screen, with a horizontal green line through the middle.  As I move the tank around, it seems like I can see changes in the horizontal line.
What do you call this?  Horizontal collapse?
What should I do next?  Help out a vector noob!   :D  :cheers:
Kevin Mullins
    • Me on Myspace
« Reply #6 on: February 26, 2010, 02:31:43 pm »
Vertical Collapse (Y axis)
Don't run it very long like that, you'll burn a dot and line into your screen.
BTW - Which monitor do you have?
« Reply #7 on: February 26, 2010, 02:47:48 pm »
I only ran it like that for like a minute...
It's a Battlezone upright, were there more than one monitor that came with it?
« Reply #8 on: February 26, 2010, 03:17:07 pm »
Found this:
1. Insufficient width or height:
A. Horizontal line (due to "Y" amplifier defection).
·  Bad "Y" amplifier output transistors.
·  Blown "Y" amplifier fuse.
·  Open fusible resistor in the "Y" amplifier.
·  Yoke pins not making good contact (very common).
·  Bad yoke.
Kevin Mullins
    • Me on Myspace
« Reply #9 on: February 26, 2010, 04:12:37 pm »
Well, it's a B/W vector.... there's only a couple I could guess it to be..... but I don't like to "guess".
And it's hard to point you at specific things to look at on the deflection pcb without knowing which monitor it is. i.e. We can't say "check Q103" if we have no idea if we're looking at the same chassis as you have.
But IF I did have to guess... I'd say it was an Electrohome G05-802.  ;)
I'd start by downloading the monitor manual, checking voltages at the harness connection, and checking all the 600 series components. (R6xx, Q6xx, D6xx, etc)
And of course ANY and ALL possibly bad/questionable solder joints anywhere on the deflection pcb.
« Last Edit: February 26, 2010, 04:16:33 pm by Kevin Mullins »
« Reply #10 on: February 26, 2010, 04:40:12 pm »
Gotcha.  I'll double-check the monitor to see what it is.  I was assuming, since it is an upright BZ, that it is a G02.
The deflection board definitely is a G02, I downloaded a schematic and used that to replace all the fuses with proper values.
« Reply #11 on: March 17, 2010, 11:07:01 am »
Anyone know of a source for Q606, Q607?
On the schematic it is a MPSU07 which appears to be obsolete (Motorola part).  These are the transistors with the big heat sinks, btw.
« Reply #12 on: March 17, 2010, 11:16:09 am »
Looks like RCA SK3199 is compatible, also obsolete...   :badmood:
« Reply #13 on: March 17, 2010, 11:21:55 am »
Nevermind, Bob Roberts has them, lol.   :applaud:
« Reply #14 on: March 21, 2011, 08:08:32 pm »
Well, replaced the MPSU07's, spot killer LED is still on, and F600 keeps blowing...  any ideas?   :banghead:
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« Reply #15 on: March 22, 2011, 09:59:13 pm »
F600 is for the Y axis amplifier. Q608,609.
http://arcarc.xmission.com/PDF_Monitors/Atari%20Monitor%20TM-151%20Issue%202%20Electrohome%20G05-802%20G05-805%20Monochrome%20XY.pdf
Page 11.....bottom left.
You need to replace that pair, and check all the components in that circuit. They are basically just a rudimentary audio pwr amp, so the same rules apply. If an output device shorts, the driver and bias components may well be taken out with it.
For the outputs, I would use something beefier. I suggest the MJ15023/MJ15024 pairs. I'm not so sure the 3716/3792 is even in production anymore, so the likelyhood of buying fakes is increased.
boardjunkie
« Reply #16 on: March 22, 2011, 11:44:34 pm »
Forgot to mention, Q608 and 609 are large metal case to-3 transistors mounted to the frame of the monitor.
http://www.zinfer.com/arcadepage/asteroids/12122002/DSCF0003.jpg
You'll have to trace wires back from the appropriate pins of the connector to identify which pair is causing the problems.
« Reply #17 on: March 23, 2011, 10:47:29 am »
Awesome, thanks!  I have those parts already, just haven't installed them.  I've been replacing known bad parts, and working my way back.  (While burning up a bunch of fuses, lol).
boardjunkie
« Reply #18 on: March 23, 2011, 02:36:53 pm »
You always work from def amp outputs back toward the input on vector monitors. From most likely to fail (output transistors) to least likely...
When you replace those output transistors, make sure you use mica insulating spacers (and fresh heatsink goop) between the transistor and the frame. The transistor mounting plate  *cannot* contact the monitor frame....
« Reply #19 on: March 23, 2011, 02:58:52 pm »
Thanks for the tips.  I'm definitely a vector n00b, and any help is appreciated.
« Reply #20 on: March 23, 2011, 04:47:56 pm »
A couple of weeks ago I was working on my Red Baron with the monitor on the ground behind the cabinet playing video.  I dropped a screwdriver and it briefly shorted an output tranny to the frame.  The spark was enough to shoot the screwdriver over the edge of the monitor and a foot away.  Nice big yellow CRACK spark.  Luckily it didn't fry the transistor but man did that get the point home.   ;D
boardjunkie
« Reply #21 on: March 23, 2011, 08:14:07 pm »
No that won't hurt the transistor, but I'm s'prised the fuse for that voltage rail didn't pop.....
« Reply #22 on: March 30, 2011, 01:41:53 pm »
Looks like I'm going to have to pull the monitor to get to those transistors.   :banghead:  I was hoping to avoid that.  Oh well...
« Reply #23 on: June 24, 2012, 07:36:53 pm »
Replaced the case mounted transistors, F600 keeps blowing...   :badmood:
« Reply #24 on: June 24, 2012, 10:50:22 pm »
It's actually a WGV2000, btw...
« Reply #25 on: June 26, 2012, 03:13:51 pm »
Talkin' to myself and feeling old...
Guess I'm going to recap, go through every 6xx component, and hope for the best.
Anyone know how to test if the case-mounted transistors are good?
lilshawn
« Reply #26 on: June 26, 2012, 05:08:38 pm »
quick and dirty is to check for a short between either leg and the case. if there is a low resistance reading then it's toast.
the better test would be to use a B&K transistor tester. but even that's not fail proof, as often with high voltage transistors, they will test good with the low voltages used during testing but fail at high voltage.
« Reply #27 on: August 20, 2012, 11:52:49 am »
Which one replaces which?
MJ15023 = ?
MJ15024 = ?
infoleather
  • Last login:September 14, 2012, 06:01:32 am
« Reply #28 on: September 06, 2012, 03:02:59 am »
If the output device shorts, driver and bias components may be removed with it.
