Author Topic: elo touchscreen cleaning  (Read 2521 times)
JimB
  • Last login:January 20, 2016, 06:52:49 pm
« on: January 31, 2010, 12:46:00 pm »
any idea's if it's possible to get behind the glass of these used elo touchscreens?  I've got some dirt specs on mine.
thanks,
jim
Kevin Mullins
    • Me on Myspace
Re: elo touchscreen cleaning
« Reply #1 on: January 31, 2010, 02:15:46 pm »
Depends on which one you have.
Some disassemble and the touchscreen will lift off, some are taped to the LCD screen itself.
dafelandry
  • Last login:March 21, 2012, 12:08:40 pm
« Reply #2 on: February 01, 2010, 10:56:15 am »
same problem... the seller made a custom package with foam packing (nicely packaged, particles EVERYWHERE) i was able to unscrew the touchscreen on the "rear" and get between LCD and touchscreen.... it was pretty obvious and things reattach with no problems.... do it slow and note where everything went... should be a peice of cake.. OR use compressed air
