Author Topic: Computer screen: widescreen vs normal  (Read 1995 times)
jonas_g
  • Last login:February 22, 2010, 06:28:14 am
« on: January 22, 2010, 10:14:10 am »
I decided that I'm going for a computer to put into my arcade cabinet. I only have doubts about the format of the screen.
Should I go for a widescreen or a normal (squared) screen ?
I'm thinking, since tv's have a squared screen I should go for the normal squared pc screen ?
Blanka
Re: Computer screen: widescreen vs normal
« Reply #1 on: January 22, 2010, 12:45:26 pm »
Do you want CRT or LCD.
CRT is mostly 4:3, you have computer monitor CRT's up to 22 inch, and TV's also around 27 inch or bigger.
The largest 4:3 LCD are 21.3 inch panels by Samsung and LG, but they are laggy and expensive, so with LCD 4:3 the HP LP2065 is the best option (nice viewing angles for vertical mounting, quick response, no noticable lag).
If you want bigger, LCD is 16:10 or 16:9. The largest 4:3 image on an LCD monitor can be made with a HANNSG 28 inch 16:10 screen. Wanting larger means you should use 16:9 TV's.
Best large quality image LCD's (the HannsG is not that well made) are the LG W2600HP, the DELL 2709 or the DELL 2711.
milkit
  • Last login:June 28, 2014, 09:14:33 pm
« Reply #2 on: January 22, 2010, 02:41:21 pm »
viewsonic makes a 28" 16:10 also
