Author Topic: Makaron + Arcade Monitor + Soft-15khz Help?  (Read 1498 times)
H8ff0000
  • Last login:January 26, 2012, 01:18:15 pm
« on: January 22, 2010, 09:03:44 am »
I've been toying around with getting Naomi working all night. Found the right files for MVC2, set everything up for Makaron T12, and it ran like it should, except that it was off the screen and I couldn't move the window. I tried making it fullscreen, and it did the 'split in half and flickering' thing that some of you might understand. I did some searching, and I found a post from the developer that said to add DIP0 = 1 to the Settings section of the Naomi.ini, but that didn't help. I also tried T11, no go there either. I feel burnt out after hours of googling. Anyone have any answer?
