Author Topic: t-molding and corners  (Read 2060 times)
vusteveii
  • Last login:July 07, 2003, 09:26:47 am
« on: July 23, 2003, 03:46:13 pm »
I've currently got some sharp corners on my cab and control panel, like 90 degree turns, how well will t-molding be able to make that kind of turn, i was thinking about cutting out a little piece of the part that goes in the kerf, just curious what kind of results you all have had with this.
steve
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
Re:t-molding and corners
« Reply #1 on: July 23, 2003, 03:51:17 pm »
I cut a 'V' out of the backside for corners.  Simple and works very well.
Hoagie_one
  • Um....whats a cabinet
« Reply #2 on: July 23, 2003, 04:21:11 pm »
or round them off with a router
RandyT
  • Last login:Yesterday at 02:15:54 pm
    • GroovyGameGear.com
« Reply #3 on: July 23, 2003, 04:22:22 pm »
This is exactly how the pros do it.  They just have a special tool that costs about $100 to cut that little "V".  A $1 razor knife works well too, just takes more time and definitely more caution!.  :o
RandyT
TalkingOctopus
    • My Arcade
« Reply #4 on: July 24, 2003, 03:19:43 pm »
I cut the V with a really sharp pair of meat scissors.  I was not really all that careful, but fortunately it turned out fine.
AlanS17
    • AlanS17
« Reply #5 on: July 24, 2003, 03:27:45 pm »
I cut it out with a sharp kitchen knife. It doesn't matter. Doesn't even need to be pretty. Nobody else is gonna be looking at it.
For a right angle you may want to completely remove the plastic across the back for about an inch. That's apretty sharp turn and a little "v" notch might not "cut it".
RedSquirrel
  • Last login:September 18, 2003, 12:07:55 pm
« Reply #6 on: July 24, 2003, 06:13:50 pm »
i think im gonna cut the grooves with a knife and make it wider with a screw driver or chisel. Might take a bit longer, but better than spending money on a router i wont use much again..
SirPeale
  • Green Mountain Man
« Reply #7 on: July 25, 2003, 08:24:54 am »
Sounds like an excellent way to break your cabinet.
BTW - They're talking about notching the T Molding itself, not the cabinet.
OSCAR
    • Oscar Controls
« Reply #8 on: July 25, 2003, 08:33:15 am »
