Author Topic: M.A.M.E. Resolution Tool v3.2 - 'runtime error 13, type mismatch' - Help?  (Read 2368 times)
dekar24k
  • Last login:April 28, 2019, 03:50:11 pm
    • ArcadeForum.com
So I decided I'd try MAME Res Tool, as it has more options and "tweakability" than AVRes but I can't get it working!
When I try to generate the game list all I get is a "Runtime Error 13: Type Mismatch" error and then the application crashes. I have installed the required system files.
My system specs:
Intel Core 2 Duo E7600 @ 3.06GHz, ArcadeVGA2 (AGP), 2GB DDR2, Win XP Pro SP3.
Running MameUIFX32 v0.136.
Any help would be highly appreciated. :)
« Last Edit: January 12, 2010, 01:14:41 pm by dekar24k »
Finished project: "The Saloon Arcade" - 2 player upright cabinet
Joystick.net - Retro gaming news and reviews
dekar24k
    • ArcadeForum.com
Ok forget about Mamerestool. I solved it using AVRes instead. I deleted the 50hz/51hz modes from the ArcadeVGA.txt file before I ran ArcadeVGARes and now every game looks awesome (at least those I've tested so far). I wasn't aware that ArcadeVGARes read resolutions from the ArcadeVGA.txt file (but now I do).
Pitou
  • Last login:July 01, 2025, 12:33:17 pm
I had the same problem. I just found out, it's because of the decimal character. Mine is ","
I did change it in the regional settings of Windows for a "." and now it works fine.
Pitou!
