Author Topic: solved..  (Read 2421 times)
dekar24k
  • Last login:April 28, 2019, 03:50:11 pm
    • ArcadeForum.com
solved..
« on: January 08, 2010, 01:05:19 pm »
Thanks.
« Last Edit: March 14, 2010, 05:46:16 am by dekar24k »
Finished project: "The Saloon Arcade" - 2 player upright cabinet
Joystick.net - Retro gaming news and reviews
bungy
  • Last login:February 06, 2020, 09:33:40 am
Re: WG D9800 issues (?)
« Reply #1 on: January 08, 2010, 03:22:32 pm »
Not sure what that dark spot is.  Have you tried putting a magnet close to see if it does anything?  May need a manual degauss.
My D9800 has a similar bump, but it's on the side. I was able to straighten it somewhat with the geometry controls.  I got it perfectly straight, but then games looked wavy in the center of the screen.  So I readjusted with a game on the screen and finally got it to look straight with the bump minimized, but still there.
What resolution are you running at?  I run at 800x600 and it looks fine, but when it switches modes to 640x480, I get a little warping in the bottom corner on one side.
dekar24k
    • ArcadeForum.com
« Reply #2 on: January 08, 2010, 04:03:18 pm »
Thanks.
« Last Edit: March 14, 2010, 05:46:52 am by dekar24k »
bungy
« Reply #3 on: January 08, 2010, 05:47:13 pm »
Yeah, manual degauss is with a wand.  I've never had to do that, but I've heard it can halp with issues where the built in degauss won't work.
A magnet can mess up your monitor, but degaussing it will fix it.  I don't think you can do any permanent damage.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #4 on: January 08, 2010, 06:47:48 pm »
degaussing should take care of it . be sure to run degausser along the mounting frame as it too can become magnetised.
mechanical shock can create the same symptom by warping the shadow mask - not repairable.
 but, external magnets can minimize the effect , if minor  ;)
dekar24k
    • ArcadeForum.com
« Reply #5 on: January 09, 2010, 02:43:44 am »
Ok thanks. I will try to get my hands on a magic degauss wand then. :)
