Author Topic: Best solution when T-molding slot is too big ??  (Read 9061 times)
JZSlenker
  • Last login:April 20, 2014, 10:06:50 pm
« on: January 07, 2010, 09:09:28 pm »
Anyone have a good way to fast T-molding when the slot is a little too big?  My main issue is that the slot around several areas (specifically the radii) are too wide to hold the T-molding in snug.  I'd consider putting some liquid nails in the groove, but I can't figure out how to hold it in around all the curves.
Sprawler
  • Last login:April 29, 2013, 08:40:00 am
Re: Best solution when T-molding slot is too big ??
« Reply #1 on: January 07, 2010, 09:25:44 pm »
haven't played with t-molding yet but here are a couple suggestions. Is the slot cutter too big or did you not cut it right? if the latter you could try filling in the gap with some builders bog and re-cutting it. If the former you could try filling the gaps with wood chips or similar to make a tight fit which should hold it in while you glue it
saleem
  • Last login:February 07, 2012, 08:03:39 am
« Reply #2 on: January 07, 2010, 09:39:05 pm »
hot glue and hot glue gun.
padstack
  • Last login:February 03, 2024, 12:54:24 pm
« Reply #3 on: January 07, 2010, 11:04:53 pm »
two part epoxy and bracing with boards until it dries.  Warning - very slow.  Prob recommend filling wiht bondo, sanding, and recutting.
RobbyMac
  • Last login:November 17, 2025, 02:31:58 pm
  • My New years Resolution is 1400 x 900.
    • My cabinet build
« Reply #4 on: January 07, 2010, 11:33:33 pm »
You can say THAT again!  :cheers:
JZSlenker
« Reply #5 on: January 08, 2010, 07:21:57 am »
I was thinking hot Glue.  Does this hold up well?   Should I just use standard multi-pupose hot glue or something more specific.  Thanks
RobbyMac
    • My cabinet build
« Reply #6 on: January 08, 2010, 07:45:55 am »
I used hi temp hot glue (not the cooler craft stuff). Squeezed some in the slot where I got a little jiggy with the router as I installed the tmolding. Had the wife holding it in behind me as I went along. It's still a slow process, just less slow with someone helping out.
saleem
« Reply #7 on: January 08, 2010, 02:57:10 pm »
its cos you need to hold the tmolding in place while the glue cools down and gos hard enough to hold it.does not take realy long,run some hot glue in the slot,press down the tmolding in the slot and hold for like 10secs.its so you can make sure its lined up and flush.
Nataq
  • Last login:October 21, 2023, 09:09:45 am
  • Arcade of the dead... now alive!
« Reply #8 on: January 23, 2010, 07:17:08 am »
I had to hot glue all my grooves cause I used 3/32 slot bit. By the way, it was written in Saints book that would be ok but that is totally false and everyone that used that bit had to use hot glue... I hope it will be corrected in the book if it is not already. Hot glue worked like a charm for me even for gigantic gaps. Just fill the groove as much as you can. You wont be able to fill it completly but that will definitly do.
bigpete405
  • Last login:April 30, 2014, 07:48:03 pm
« Reply #9 on: January 24, 2010, 09:34:03 pm »
I put wood glue in the t-molding slot where it was cut wrong, then put the t-molding in with tape holding it until the next day when it was dry and good as new.
UberCade
  • Last login:March 19, 2021, 11:22:32 pm
« Reply #10 on: February 17, 2010, 03:05:01 am »
The thing with wood glue is it doesn't bond plastic, rubber or vinyl to wood well at all. I know because I've tried. Wood glue is designed to bond wood to wood and nothing else. You're better off using the hot glue method (I'm even unsure about the strength of that) or best yet filling the problem areas with Bondo and recutting like other people have mentioned. Honestly that would be your safest bet. Sure it will take the longest, but you'll get the best results.
