Author Topic: The Force Is All around us....  (Read 3132 times)
ienjoy
  • Last login:February 28, 2012, 12:00:52 pm
« on: January 07, 2010, 08:27:27 am »
I'm planning on turning this:
Into a Star Wars upright using the Yoke of this:
Re: The Force Is All around us....
« Reply #1 on: January 07, 2010, 10:28:53 pm »
Interesting project.  Are you going to go with original Star Wars artwork?
ienjoy
« Reply #2 on: January 08, 2010, 01:03:41 am »
I would love to as much as possible but the budget for this is about £0  ;)
ienjoy
« Reply #3 on: January 11, 2010, 03:28:27 pm »
OK started stripping down the Pharoahs Gold:
And removed the control panel from Vapor Trx:
While taken out I noticed the yoke has a motor attached:
Could I use this some how for force feed back/rumble?  ???
saleem
  • Last login:February 07, 2012, 08:03:39 am
« Reply #4 on: January 11, 2010, 05:01:32 pm »
well if the motor isnt capable of force feed then i doubt it.i would have thought for force feed you would have had to buy the correct (is it a yoke?) type.
ienjoy
« Reply #5 on: January 11, 2010, 07:40:57 pm »
I meant as I'm going to be using emulation in this cab then perhaps I could rig something up to 'jiggle' the motor back and forth to emulate rumble .
For example if I hack a controller that has rumble then I could connect the rumble wire to a circuit with a relay to switch on a mono stable multi vibrator (anyone remember them?). That could flick the voltage back and forth causing the motor to run back and forward giving a rumble effect on the yoke.
For force feedback something similar where it try to steer the opposite way giving you a hard time to steer.
Wasn't there a hacked mame or final burn that had force feedback?
« Last Edit: January 11, 2010, 07:48:47 pm by ienjoy »
ienjoy
« Reply #6 on: January 14, 2010, 11:24:40 am »
Change of plans. Won't be using this cab.
Pics later
ienjoy
« Reply #7 on: January 15, 2010, 06:04:33 pm »
OK complete change of plans now. Still gonna be a Star Wars Cab with Yoke but I may add 2 player controls.
Still undecided.
