Author Topic: Does a tri-sync monitor auto sense resolutions?  (Read 2030 times)
secret80sman
  • Last login:March 14, 2013, 07:04:31 pm
    • The Ultimate 80's Tribute Band
« on: January 03, 2010, 04:39:15 am »
This may be obvious to most of you but does a monitor like a wg9800 auto sense what Windows is giving it? ex. 15, 25, or 31? And does the fact that it is tri-sync mean it cannot be damaged by whatever video signal windows feeds it unlike an older arcade monitor?
thanks in advance.
grantspain
Re: Does a tri-sync monitor auto sense resolutions?
« Reply #1 on: January 03, 2010, 07:28:29 am »
the 9800 will auto detect 15-38khz,as long as your signal is within that range you will not damage the monitor-as far as i am aware all modern digital chassis basically shut down if the signal is too high so there is no chance of damage
secret80sman
« Reply #2 on: January 03, 2010, 08:11:42 am »
Thanks Grant, I tried a couple of different resolutions and sometimes there is a flicker that looks terrible. I guess if it doesn't damage anything then no worries. Does Soft-15khz automatically swap resolutions depending on what you tell it to or based on specific resolutions? For example 800x600?
grantspain
« Reply #3 on: January 03, 2010, 08:30:27 am »
sorry i don't know anything about soft 15k but there is a massive thread about it on the forum so i would suggest reading all the way through
secret80sman
« Reply #4 on: January 03, 2010, 09:30:29 am »
Have read through some of it, you are correct, it is massive. Back to school for me on this subject then.
Jack Burton
« Reply #5 on: January 03, 2010, 02:29:26 pm »
If you're seeing flicker then you are probably in interlaced mode.  Did you install all three modes with Soft 15khz?  If you only install 15khz mode then 640x480 will be interlaced.
