Author Topic: How to change keys of zinc  (Read 3451 times)
jmr15
  • Last login:February 16, 2011, 08:17:24 pm
« on: December 27, 2009, 04:57:23 am »
I  try change but dont works
first i use the gui to change the keys
 to launch any game but dont works
only the default keys works
afeter i change the keys in zincconfig.exe but dont work
so how can i save the keys because i did the tutorial but dont works
 :banghead: :banghead:
jmr15
Re: How to change keys of zinc
« Reply #1 on: December 28, 2009, 05:42:26 pm »
the problem is the file
controller.znc
this file have buttons type mame
the zincgui and zinccab not use this file but in mala you use the wrapper and the wrapper use the zincconfig and the zinc config use the controller.znc
now how edit this file please give me the answer :hissy: :hissy:
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #2 on: December 29, 2009, 11:46:16 am »
checkout my config & wrapper utility (ZincCab):
http://forum.arcadecontrols.com/index.php?topic=86588.0
Its some time long ago I wrote ZincCab and configure it a bit different way by using number of buttons instead when you configure. If the games works if you launch it directly from the config, then it should works from Mala (was designed with MultiFE in mind), but you do need use to use ZincCab as a wrapper too (using same zinccab.exe), elsewise it does not launch the correct config settings.
« Last Edit: December 29, 2009, 11:49:20 am by Space Fractal »
jmr15
« Reply #3 on: December 29, 2009, 04:06:37 pm »
hi well I did the tutorial of the forum and you need the wrapper by howardcastro
and to change the file controller.znc we need to use the zincgui
after in folder pcfg  we will have the new controller.znc
only overwrite(copy and paste) the file in main folder(c-emulators-programs-zinc)
and thats all when you choose any game the new  keys works
i  will try use the zinccab
 :burgerking: :burgerking:
« Last Edit: December 29, 2009, 04:35:53 pm by jmr15 »
