Author Topic: nlited xp or regular windows 7?  (Read 2231 times)
milkit
  • Last login:June 28, 2014, 09:14:33 pm
« on: December 26, 2009, 01:58:10 pm »
I am building a new mame cab and I bought this hardware, I am going to run 64 bit and need to know which would be best...
An N-lited version of windows xp pro 64-bit
or stock (since there is not a "lite" program for 7 that i know of?) windows 7 home premium
Obviously a lite version helps because less stuff is running, but windows 7 im guessing makes better use of 64 bit and dual cores. Here is my hardware:
Amd Athlon II X2 250 Dual Core 3.0ghz
2gb ddr2 Ram
500gb sata
Any suggestions?
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
Re: nlited xp or regular windows 7?
« Reply #1 on: December 26, 2009, 02:10:48 pm »
Just keep xp
your not even gonna see or use the new features when running the front end over it and you may run into compatibility issues
milkit
« Reply #2 on: December 26, 2009, 02:58:20 pm »
well i was planning on turning off most of the visual aspects of windows 7 (aero, peek, etc)
but you dont think the bare perfomance enhancements would be worth it? (seeing as dual core and 64 bit is now a major focus)
BobA
  • What Me Worry?
« Reply #3 on: December 28, 2009, 10:52:29 am »
There is a Tiny 7 available from usual sources.   It is not available in 64 bit and probably will not be.
Gamester
« Reply #4 on: December 28, 2009, 08:55:12 pm »
I would stick with XP.  There really is no compelling technical reason to use Win7 over nLited XP for an arcade cab.  As a previous poster mentioned, with Win7 you also take the risk of having compatibility issues.
Karnako
  • Last login:September 19, 2021, 09:06:43 pm
« Reply #5 on: January 05, 2010, 02:48:15 pm »
Apparently nLite and vLite are abandoned now...Anyway, if you care about stripping parts of Windows 7, I suggest you to check vLite forums: http://www.msfn.org/board/vlite-f153.html You'll find some guides there, although I cannot recommend any specific.
Considering that Vista is usually pointed as better than XP on 64-bit, maybe 7 would be a good try. However, you may fall on compatibility issues as everyone suggested. On this sense, I would try Ultimate (Professional maybe?) as it has the XP compatibility mode - home editions don't have it.
