Author Topic: Can you cut the Flyback wire to make it longer? see post...  (Read 2101 times)
ZEN
  • Last login:March 20, 2013, 12:01:07 am
  • go get it....
« on: December 19, 2009, 03:20:42 pm »
I need to take a PC monitors wire from the flyback to the monitor and make it longer, can I splice 6-8 " of wire in there, or will it mess with current flow, etc?  Probably a noob question but I guess I just want to be sure... :dunno
GO BIG RED
grantspain
Re: Can you cut the Flyback wire to make it longer? see post...
« Reply #1 on: December 19, 2009, 03:28:42 pm »
you would need to seal the connection with the correct amount of insulation otherwise it will arc,i have never seen it done myself
Kevin Mullins
    • Me on Myspace
« Reply #2 on: December 19, 2009, 04:39:27 pm »
I would not recommend it. Rather relocate things so that it will reach naturally.
You have to remember there is between 12-20 THOUSAND volts on that line.
ZEN
  • go get it....
« Reply #3 on: December 19, 2009, 06:58:27 pm »
How about the degauss wires, those should be okay to cut and extend right?  I have to cut one or the other to get this to fit..... :banghead:
GO BIG RED
SirPeale
  • Green Mountain Man
« Reply #4 on: December 19, 2009, 08:35:22 pm »
They're special wire.  You don't want to cut them either.  Though you can probably live without them and manually degauss if you have to.
Explain the circumstance, please!
ZEN
  • go get it....
« Reply #5 on: December 20, 2009, 03:04:53 am »
Well, I am trying to put a normal CRT into an older WG 4900 monitor brackets, the neckboard at the angle I am installing needs to sit kinda low, I dont want to use a LCD so I am trying to get this CRT in the cab, I just am having a hard time getting the wires to fit, so I cut the degauss wires  and just added spades and recepticles to it, no arcing can occur, I just done want it to be a problem, its a 19" Viewsonic, If I "fewk" it up I suppose its $10 down the drain, but I just dont want the hassle, trust me, i have no options here to get to fit right without cutting the degauss since I should not mess with the flyback wire..........I guess I will see what happens, unless you all think its definite failure..........
GO BIG RED
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #6 on: December 23, 2009, 09:32:04 pm »
the anode lead can be spliced if one can find a hv splice kit.  otherwise NOT recommended.
focus lead also requires special insulation as it can carry 6kv - 12kv.
screen grid is not as much of a problem as usually <500v max. should still insulate securely
for deguassing wires , use same wire guage as orig , and insulate accordingly (120vac usa)
