Author Topic: got 3do emu working but its so slow  (Read 3366 times)
adidas1984x
  • Last login:January 06, 2023, 07:14:53 am
« on: December 10, 2009, 02:15:21 pm »
got the 3do emu working my pc specs are dual core amd 64x2 3 gigs of ram but its runs so slow and the version of freedo is 1.9wip
« Last Edit: December 11, 2009, 08:00:40 am by adidas1984x »
adidas1984x
Re: got 3do emu working but its so slow
« Reply #1 on: December 11, 2009, 08:09:23 am »
bump (updated info)
brian_hoffman
  • Last login:July 02, 2011, 09:02:20 pm
« Reply #2 on: December 11, 2009, 07:26:45 pm »
unclet
« Reply #3 on: December 11, 2009, 08:25:14 pm »
It was been forever since I first install 3DO, but I thought I should mention that I got it working with freedo 1.7wip and it seemed ok at the time.
« Last Edit: December 13, 2009, 09:14:27 am by unclet »
adidas1984x
« Reply #4 on: December 12, 2009, 06:43:41 pm »
i cant seem to find a working 1.6 or 1.7 any suggestions
zorrobandito
  • Last login:October 04, 2025, 12:11:09 am
    • Zorro's Classic Games
« Reply #5 on: December 13, 2009, 07:24:37 am »
Here you go.
unclet
« Reply #6 on: December 13, 2009, 09:20:44 am »
Yeah I actually used freedo 1_6_2.
Below are some of my notes regarding 3DO.   Not sure if you need to do all of these or not ... it has been too long:
1) Unzip the "freedo_1_6_2.zip" into a freedo install directory
2) Unzip the "FreeDo17WIP.rar" into the freedo install directory (replacing the EXE)
3) Unzip the "jcrouse-3do-wrapper(freedoV1.7WIP).zip" file contents into the freedo install directory
Also do this:
- Start the "D:\Emulators\Programs\freedo\FreeDO.exe" application and select
  the "File\Select Bios" menu option and then enter the file name of
  "D:\Emulators\Programs\freedo\fz10_rom.bin".  For some reason this
  association is not maintained and must be performed manually.
- Start the "D:\Emulators\Programs\freedo\freedo.exe" and go into
  the "Config\VDL" menu and set the Extrapolation option to active.
  This allows 3DO games to display properly on my TV.
