Author Topic: What are the differences in Pole Position vs. Pole Position 2  (Read 6796 times)
« on: December 07, 2009, 01:12:24 pm »
Which is a better game and why?
Kevin Mullins
    • Me on Myspace
Re: What are the differences in Pole Position vs. Pole Position 2
« Reply #1 on: December 07, 2009, 05:44:21 pm »
PP2 has more tracks.
THE POKER BRAT
  • Last login:August 04, 2015, 05:50:58 am
« Reply #2 on: December 07, 2009, 07:54:16 pm »
the difference between the two,..is that one is problem prone to all kinds of breakdowns,..the other one is just as sucky,...
dont get me wrong,..pole position is a fun game (i like it, and have it on an emulated machine).
but dont waste your time with an original,..theres much more "durable" & "dependant" driving games out there.
just my opinion.. :dunno
WANT LIST: , asteroids mini, crazy climber mini, tron mini, goldball PINBALL,.
« Reply #3 on: December 08, 2009, 08:05:17 am »
I know that...   ::)  I was more interested in knowing if the control 'feels' any different...
« Reply #4 on: December 08, 2009, 08:06:10 am »
Ehh... It's gotta be a Pole Position (or PP2).  It's for my wife, and it's a nostalgia thing.  So another driving game just wouldn't cut it.
Kevin Mullins
    • Me on Myspace
« Reply #5 on: December 08, 2009, 10:22:15 am »
Most PP2's were conversions of PP1's, so the controls and such would have been the same anyways.
As far as actually "in game" control..... I dunno..... never payed much mind to that.
« Reply #6 on: December 09, 2009, 12:47:03 pm »
I can't cite any specific examples why, but I prefer PP1 to PP2; just more fun and memorable to me
« Reply #7 on: December 09, 2009, 01:01:12 pm »
Yeah, that's my concern.  My wife's holy grail is PP1 (nostalgia, and all that), and a working PP2 just came up locally...
« Reply #8 on: December 09, 2009, 02:41:16 pm »
So get the PP2 and get a PP1 board? or is that not an option?
« Reply #9 on: December 09, 2009, 02:47:58 pm »
I dunno, I would assume so if people converted the other way around...
« Reply #10 on: December 09, 2009, 04:25:43 pm »
IIRC they control identically for the reason Kevin stated.  I don't see any preservationist argument against putting PP1 in a PP2 cab.
Pinball Wizard
« Reply #11 on: December 10, 2009, 03:22:08 pm »
It might just be adjustments but the PP2 I played seemed to steer "quicker" than PP1. By "quicker" I mean with less spin. Personally a fan of PP1 more than PP2 but they play pretty close to the same.
Where's my gold star :P
CrazyKongFan
  • Last login:June 06, 2017, 01:22:29 pm
« Reply #12 on: December 13, 2009, 11:45:03 am »
Watching Richie Knucklez (if any of you guys know him or know who he is) play both games at Funspot, it seemed like PP2 was more responsive. I know he told me that riding the edge stripe didn't slow you down nearly as much as on PP1 (and he's insanely good at both).
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #13 on: December 17, 2009, 12:22:11 pm »
Doesn't PP2 include the PP1 track ?
Also, Poker Brat's warning is valid. The hardware breaks down. But I've heard of mods that can be done to fix that, and you could also throw in some fans.
NO MORE!!
FrizzleFried
    • Idaho Garagecade
« Reply #14 on: December 18, 2009, 01:09:47 pm »
I own both boards... and for anyone who cares to listen... these boards can easily be bulletproofed.  The number 1 issue with PP and PP2 boardsets is the edge connector where the +5 comes in.  Bottom line is that the edge connector should have had 2 or 4 more +5 pins but because they didn't they heat up the edge and the connectors and or traces near the edge connectors start to fail.  As they start to fail the SENSE feature of the AR boards senses that there is less and less +5 making it to the boardset so it ups the voltage to compensate... as it ups the voltage it causes the edge connector and/or traces near it to fail even more eventually burning something out.  To bulletproof the boardsets simply run wires from each +5 test tab and each GND test tab on both the video and mainboards to two separate molex connectors... then you can either add a molex connector to the current power supply +5 and GND wires or do what I did and run them to a dedicated switcher.  If you go with the switcher route,  make sure to disconnect the +5 coming from the AR boards at or near the PCB edge connectors (both mainboard and video... and there are more than one so be careful).  I will post a picture of my PP boardset below.  It looks sort of "hacked" but trust me... it works great.
Now... I prefer PPII.  Why?  Because of a number of reasons.  (1) It has more tracks (including the original's Fuji).  (2) It's much MUCH faster gameplay.  PP tops out at about 60-70% the speed that PP2 tops out at.  (3) I prefer the sounds of PP2 to PP... other than the engine noise that is.   What you will want to know though is that PPII does have at least 1 bug that I've discovered (and confirmed with other PP2 owners)... when you get to close to max speed,  there are times when you swerve off the road (usually in a corner) and back on the road you will hear the engine noise twitch a little and then increase...regardless of whether you are speeding up or slowing down (due to being off road).  During this "bug",  your cars speed increases at about 2 to 3x the normal acceleration maxing out at 330MPH very quickly... if you crash or let off the gas the "bug" ends and you're back to the normal speed/engine sounds.   If you can learn to use this "bug" to your advantage you can get some pretty good scores.   I've confirmed this issue with a half dozen PP2 owners.   It usually only happens on the TEST track though I've had it happen on Fuji before only because they're the only tracks you can get close enough to max speed for the bug to kick in... the other two tracks are just brutal.
My cab currently only houses 1 boardset and it's been PP2 for about 90% of the time.  I do have a 2nd PP PCB cage coming in the mail (today?) and I plan on reversing both cages and attaching them to each other so I can swap games by sticking my hand through the coin door and moving the two edge connectors and two molex connectors from one to the other.
Here is a pic of my bulletproofed PCB:
« Last Edit: December 18, 2009, 01:12:52 pm by FrizzleFried »
