Author Topic: What's the minimum spec required to run Visual Pinball?  (Read 5027 times)
slapaham
  • Last login:January 31, 2012, 05:32:32 pm
« on: December 07, 2009, 09:28:45 am »
I'm not new to what's required to run MAME competently but I definitely am when it's come to Visual Pinball...
What would be the minimum competent set-up for Visual Pinball...? When I mean competent, I mean no stuttering, sound problems, etc... ;)
billpa
  • Last login:October 01, 2017, 11:25:31 pm
slapaham
Re: What's the minimum spec required to run Visual Pinball?
« Reply #2 on: December 07, 2009, 10:19:52 am »
Ta for that! :)
billpa
« Reply #3 on: December 07, 2009, 10:59:16 am »
np...check out the HyperPin forums as well. There are at least a dozen active cab projects going on right now. Ask questions over there...you will get answers from people that have experience.
slapaham
« Reply #4 on: December 07, 2009, 01:12:41 pm »
It's strange... the PC I was going to use has a fairly decent spec (though is probably a little low on the RAM side) and that doesn't seem to want to run any of the tables - Visual Pinball complains about virtual memory! :-\
I guess what might be the best option is to swap that PC over with the one I'm using for the touchscreen monitor... SK Jukebox surely doesn't need much spec to run well... and that PC is probably just being put to waste being used for that... means transferring all the files across though which is a bit of a pain in the arse!
billpa
« Reply #5 on: December 07, 2009, 03:12:40 pm »
What are the specs of the PC? And can you be a little more specific about VP complaining about virtual memory? Is there some sort of error you are getting when you are launching a table?
Deadly
  • Last login:April 28, 2021, 02:55:25 am
« Reply #6 on: December 07, 2009, 04:45:43 pm »
Long story short the CPU has cache, when it is consumed it off loads to the RAM, when that is consumed it is then offloaded to the windows swap file which is your virtual memory. So now knowing this, you simply don't have enough RAM and your page file is too small. Either add more RAM and/or increase your page file (sometimes referred to as the swap file).
« Last Edit: December 07, 2009, 04:47:43 pm by Deadly »
slapaham
« Reply #7 on: December 07, 2009, 06:43:53 pm »
Ah, ok... thanks for that info. I think it might be sensible to swap the computers around anyway... the older one is still a good spec but using it for a juke is hardly going to push it - whereas the other PC is quite a bit more powerful and would be better at handling the graphics of the pinball...
