Author Topic: Weird Mame 2P phenomina - Insight Needed  (Read 2532 times)
rezero
  • Last login:February 06, 2010, 11:07:20 pm
« on: December 03, 2009, 09:59:19 pm »
I am running Mamegui (mame32), and using a keyboard mapper, all of my controls are showing working correctly.  When I play games in mame, the player 2 joystick does not function (the player 2 button work fine).  When I went back to the mapper, al of the proper buttons lite up when I moved the player 2 joysirck (q,f,....).  This tells me that the joystick is working fine and sending the correct signals to the PC.  Any thoughts why it does not work when running mame.
speedklz
  • Last login:November 17, 2018, 12:56:23 pm
Re: Weird Mame 2P phenomina - Insight Needed
« Reply #1 on: December 03, 2009, 10:47:34 pm »
What are you using to connect the joysticks to the computer? keyboard hack, I-pac?
Best of the Best of the Best. Sir!
ideft
  • Last login:February 11, 2012, 04:06:09 pm
  • "Mister, I suspect you to be a dope fiend"
« Reply #2 on: December 03, 2009, 11:40:36 pm »
Have you remapped the keys within Mame to coincide with your key presses???
rezero
« Reply #3 on: December 04, 2009, 06:23:46 pm »
I am using a keyboard hack.  But as I stated I am using the normal keys for the player 2 joystick (f,q,r...).  In addition, when I go into MSWord or something and move the joystick, the letter come up just as prescribed.  This tels me the joystick and controller is sending the right signals to the computer.
Hoopz
  • Intellivision Rocks!
« Reply #4 on: December 04, 2009, 06:28:16 pm »
Within Mame and in a game, hit TAB and scroll to the option for all games, and see if P2 joystick movements are programmed within Mame itself.  With what you are doing within Word, you see that it should work.  That means something within Mame itself isn't matching what you have.
Did you change the default configs at all or anything?
speedklz
« Reply #5 on: December 05, 2009, 01:50:18 pm »
Is it a ps/2 or usb keyboard?
headkaze
  • Last login:July 05, 2026, 01:56:04 pm
  • 0x2b|~0x2b?
« Reply #6 on: December 05, 2009, 09:24:17 pm »
What do you mean by "using a keyboard mapper"? Are you using software to convert the joystick signal into a keyboard signal? If so new versions of MAME uses Raw Input to read the keyboard so you cannot use software such as XPAdder with MAME unless you compile a version that forces it to use DirectInput. Why not just use the joystick directly in MAME without mapping it to a keyboard?
rezero
« Reply #7 on: December 06, 2009, 01:53:10 am »
USB Keyboard.  The mapping program is just a typing tutorial that shows the keys that you hit when they are struck.  It is not part of mame but I used it when I was instaling al of my wiring to ensure everything was correct.  When running mame it is not used.  All key are programed in mame for the specifric game I am using.
