Author Topic: Can you recommend a place to have a small CP type label printed?  (Read 1918 times)
alank2
  • Last login:June 25, 2023, 10:05:48 pm
« on: December 02, 2009, 09:15:36 pm »
Hi,
I have a product I am looking to have a label made for.    Perhaps 2" to 2.5' inches tall by 8" long.  It will also need to have five 3/8 holes punched into it.  It needs to be peel and stick on so I can attach it to a plastic enclosure.
Can anyone recommend a printer or company that could produce this type of thing?
What type of material should I have it printed on?
All ideas welcome,
Alan
ItchyD
  • Last login:July 08, 2017, 03:38:24 pm
Neverending Project
    • Arcade Fixer
Re: Can you recommend a place to have a small CP type label printed?
« Reply #2 on: December 03, 2009, 11:34:05 am »
Is it for production or just for personal use? If it is the latter, could you just print from a home ink-jet printer onto a label?
alank2
« Reply #3 on: December 03, 2009, 11:36:21 am »
Hi,
It is for a product I am producing, but I thought about doing them myself depending on how difficult it would be.
Do they make glossy or textured sticky backed inkjet printable labels?
Thanks,
Alan
RobbyMac
  • Last login:November 17, 2025, 02:31:58 pm
  • My New years Resolution is 1400 x 900.
    • My cabinet build
« Reply #4 on: December 03, 2009, 04:16:27 pm »
Try your local next day signs or vinyl graphics sign shop.
They can print on an assortment of materials, and cut the holes etc...
Most vinyl require a smooth non porous surface to adhere to.
However, they can also print on some plastics/lexans (extremely thin) for instrumentation panels, guage faces, etc... all with the ability to be back lit.
Most sign shops have small format printers (some use a gerber edge thermal heat process, others inkjet with a laminate) and can cater to small runs/prototyping as easily as the larger volume orders.
Don't blame me when you see all the different materials they have and come back with a gazillion new ideas. ;)
