Author Topic: Button inputs with E-touch  (Read 1754 times)
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« on: December 01, 2009, 09:09:27 am »
Anyone tried running the latest E-touch using only buttons? In effect you can use it with a minimum of 3 buttons to select albums and pick tracks, these being LEFT, RIGHT and SELECT. You can go through the albums select and album go through the tracks and select the track. You can have it set to auto add to queue. With an aditional cancel button you can leave the auto add to queue off and then just assign the same key to add to queue so when the play options screen appears they can press select or cancel in case the song was selected by error.
The reason i am posing the question is to see if there is any interest in this to the point of me expanding the keyboard operation to other screens like top 10 and search or not. Feed back in this thred on over on the E-touch/Freebox site would be great.
