Author Topic: Test renders, my new cab  (Read 5898 times)
steve_pss
  • Last login:December 19, 2020, 06:56:53 pm
« on: July 21, 2003, 12:45:22 am »
Dont mind the CP layout, still working on it
F|end
  • Last login:October 20, 2007, 07:27:59 pm
  • I'm 250 euros away from a working cabinet...
Re:Test renders, my new cab
« Reply #1 on: July 21, 2003, 05:40:27 am »
 ;DNice stuff man! ;D
I wonder if the "monitor hole" isn't a little bit high!? The excess or lack of space can be a pain in the ... when building a cab, if it has incorret measurements... ;)
Well, that's my full sincere opinion! Hope that you don't misunderstand it!  :)
Pedro Vieira
steve_pss
« Reply #2 on: July 21, 2003, 09:19:54 am »
you opinion is spot on. still working on the overall height of the cab/cp, etc.
hopefully tonight i can tighten that up and get the CP layout done right.
AlanS17
    • AlanS17
« Reply #3 on: July 21, 2003, 10:25:49 am »
If you plan on using a TV then you may want to go out and decide which TV you plan on using/buying before you build. That way you have a perfect fit. After all, how often do you plan on switching out tv's for this thing? I would imagine not at all.
Plus being a bit tall doesn't hurt. You can always raise/lower the shelf and the best TV's have the speakers mounted below the screen rather than on the sides to ofer a larger maximum screen. This results in a taller TV, anyways.
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #4 on: July 21, 2003, 10:31:46 am »
Is it going to be a "sit at" machine? The scale seems to be a little wonky with that big monitor hole. It's hard to determine.
If you build a frankenpanel, chances are I don't care for you as a person.
steve_pss
« Reply #5 on: July 21, 2003, 05:12:33 pm »
here it is with the height at 6'2 and the CP height at 31"
AlanS17
    • AlanS17
« Reply #6 on: July 21, 2003, 05:18:58 pm »
That new one may actually be a bit shorter than you might want. It all depends on the monitor you drop in it. Most arcade machines had a square opening for the monitor so it could handle either a vertical or horizontal screen by rotating it in the square.
However, most TV's are not square so if you're building this thing from scratch you have the advantage of making it perfectly fit any TV you decide to use in it. In that situation I would consider choosing your TV before deciding on final dimensions. Different TV's are wider, taller, etc.
Of course, if you use an arcade monitor, then none of this matters and a square will work just fine.
steve_pss
« Reply #7 on: July 22, 2003, 10:04:08 am »
actually its going to be a 19" VGA moniter with the base taken off.  The overall measurements take that into effect and I plan on using are board between the moniter and bezel to hide the casing (which will be painted flat black).
F|end
« Reply #8 on: July 22, 2003, 10:20:31 am »
 ;D An advice:
Make the monitor hole measures to a wells gardner 27''!
Belive me, that monitor means mass destruction and you can allways want to buy one! Make allways a little more space to change when you want!  ;D
Pedro Vieira
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #9 on: July 24, 2003, 08:11:04 am »
Looks good! ;D
I wish I had the patience/skill to render! :(
All Your Base Are Belong To Us!
