Author Topic: Magnetically shielded case fan???  (Read 2051 times)
TeamTEOR
  • Last login:December 14, 2018, 09:43:43 pm
  • Off to the Edge of Reality
    • My Website
« on: November 28, 2009, 05:05:29 am »
Does anyone know where I can find a magnetically shielded case fan? It is awe full hot in that arcade machine of mine. and I'd like to add some cooling to it.  I figured that I would use a hole saw on the top on the cab to cut out a hole for a fan, but I am afraid that a standard 110v fan would send out a magnetic field and make the video shake.
BobA
  • What Me Worry?
Re: Magnetically shielded case fan???
« Reply #1 on: November 28, 2009, 09:41:07 am »
Use a 12v pc fan and you will not have any problems with affecting the video.    I have used 120V fans at the top of a bartop and they did not affect the video but my monitor still had its metal shroud on it.
TeamTEOR
    • My Website
« Reply #2 on: November 28, 2009, 01:34:28 pm »
Ok, will try out some 12v fans up top. I am using an unshielded BilLabs 25 inch monitor, so I think the 120v fan I have is not going to be a good thing above it. I won't need the heat on when the machine is on, that is for sure. It should warm up the room nice.
