Author Topic: New AimTrak Firmware/Software  (Read 11666 times)
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« on: November 27, 2009, 04:55:29 pm »
A new version of firmware and config utility is now available for the AimTrak.
Release notes are here, giving details of changes: http://www.ultimarc.com/relnotes.html
Firmware link is at the foot of the updated info page: http://www.ultimarc.com/aimtrak.html
Andy
Queeg
  • Last login:August 30, 2024, 04:25:21 am
Re: New AimTrak Firmware/Software
« Reply #1 on: November 27, 2009, 05:03:55 pm »
Great, thank you for the update.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: November 27, 2009, 05:09:27 pm »
Nice. Now I need to get off ---my bottom--- and solder that new board in....
BobA
  • What Me Worry?
« Reply #3 on: November 27, 2009, 05:34:27 pm »
Great.  Thanks for upgrade.   :applaud: :applaud:
TeutonicDarkness
  • Last login:July 16, 2019, 10:54:16 pm
« Reply #4 on: November 30, 2009, 06:55:28 pm »
 I have been messing around with this new firmware and software.
I do think its a lot better than previous version.
( Especially love being able to track 2 cursors on desktop)
 However I have noticed that my Laptop does not like the
new version at all!  :(
I'm sure it is probably some changes that were made not agreeing
with my setup. I am sending video out of my laptop by S-Video cable
to the TV. So I'm trying to use the TV to track instead of the
tiny Laptop screen.
It wasn't perfect with version 1 on Laptop
but version 2 on Laptop Jitters like made. is uncontrollable and is
prone to completely lock up.
Even if I can Never use it on Laptop that is OK...
Because it is Flawless on My 19 in Crt Monitor...  :)
OK Don't want to interrupt the thread...
Just Rambling.
mytymaus007
« Reply #5 on: November 30, 2009, 11:14:14 pm »
Whats the latest on AIM Track, is it stable from readings its seems to be the one to buy over all other light guns.What seems to be the best gun to rip apart, with the least amount of hassle
Neverending Project
    • Arcade Fixer
« Reply #6 on: December 01, 2009, 02:42:30 am »
Have you tested on XP x64? I am not able to get the firmware updater to work. The software works, and immediately tells me I need to update my AimTrak firmware (1.1). When I click the Assign ID, then Upgrade button and then OK it gives a Windows error trying to launch the uupload exe file. Attached are the results it wants to send to Microsoft, if that helps at all.
Does it rely on any services? I have disabled some, and maybe that is causing an issue? I also tried running uupload.exe as Administrator, and without restrictions with the same result. Any other thoughts?
Neverending Project
    • Arcade Fixer
« Reply #7 on: December 02, 2009, 02:40:13 am »
FYI, I was able to use another computer (32-bit XP) and update the firmware of the AimTraks. So it appears to be either a XP x64 issue, or an issue with a service not being available.
AndyWarne
    • Ultimarc
« Reply #8 on: December 02, 2009, 11:04:17 am »
We didnt test the firmware update utility on XP64 so there may well be problems. I will do some further testing on Windows 7 64 and maybe that will uncover some issue which might apply to XP64. Only the update utility is affected, the device would work of course on XP64.
« Last Edit: December 05, 2009, 03:55:58 pm by AndyWarne »
