Author Topic: Yoke, Purification Rings and tube for a WG 19" K7000  (Read 3504 times)
atomikbohm
  • Last login:January 22, 2018, 11:33:35 am
« on: November 24, 2009, 06:12:58 pm »
I've come across a chassis for a 19inch Wells Gardner K7000 monitor and haven't been able to find a Tube, Yoke and/or purification rings.  Can anyone tell me where to go from here?  ???
The way I see it I have to ...
1) Find someone on a forum like this that has spare 19 inch K7000 rings and yoke laying around and then find a local tube to match.
2) Get information from someone here that knows of a TV Brand and model that has a compatible tube ( + Yoke and rings)
3) or some other way that I haven't thought of yet.
The local arcade shop either doesn't have any or is unwilling to look around their parts room.  :banghead:
Any suggestions would be greatly appreciated.
Ken Layton
  • Guru
  • Technician
Re: Yoke, Purification Rings and tube for a WG 19" K7000
« Reply #1 on: November 24, 2009, 08:57:29 pm »
The problem is some 19" K7000's had 22.5 mm neck (8 pin) tubes while others had 29 mm neck (10 pin) tubes. You need to look at the neck board and see what "P" number it is.
atomikbohm
« Reply #2 on: November 24, 2009, 11:38:55 pm »
My chassis board numbers are:
P447 for the chassis board
P456 for the neck board
The socket on the neck board has 8 pins (7 plus 1 for the cathode{If I'm using the correct term})
If I'm understanding Wells Gardner's model number conventions correctly the chassis is for a 19" K7000 series chassis not a K7203(P819 Main P826 Neck), K7201 (P757 Main P760 Neck)or K7300 (wasn't able to find the numbers tonight) series)
atomikbohm
« Reply #3 on: November 30, 2009, 03:26:26 pm »
Anyone here who can help me out?
