Author Topic: Torrent client with good file selection needed  (Read 3112 times)
Blanka
« on: November 24, 2009, 10:24:05 am »
Probably many here probably know the problem ;)
Take a 10Gb+ torrent with 10000 files. You only want 200 files to download.
I need a torrent client that:
- allows sorting the files by name and selecting the ones to download
- only puts the selected files in the download folder. Not the files that share the same download-chunks as the wanted files too.
- works on OSX 10.4 or Win XP
Anybody know a good one?
Re: Torrent client with good file selection needed
« Reply #1 on: November 24, 2009, 10:27:13 am »
Vuze
Blanka
« Reply #2 on: November 24, 2009, 10:29:50 am »
How is Vuze today? I remember the old days of bloated bundle-wared Azureus, guess that one was converted to Vuze later. Lean and mean again?
« Reply #3 on: November 24, 2009, 10:30:35 am »
Ehh... it's still bloated, but it will do what you want.   :-\
Hoopz
  • Intellivision Rocks!
« Reply #4 on: November 24, 2009, 10:42:44 am »
uTorrent handles that fairly well.  I frequently select a small number of files from a large torrent.
I may be missing something from your second bullet point though.  I dont think uTorrent does that but I always move files around once the torrent is complete and delete the old containing folder.
Blanka
« Reply #5 on: November 24, 2009, 11:05:35 am »
Vuze does pretty good on the selecting (but horribly slow), but it creates ALL files in the download folder and demands all Gb to be free on the HD  :banghead: :cry:
This makes Vuze a worse option than Transmission is, so both are bad.
MuTorrent does not run on OSX 10.4, but i can try the windows version at home.
« Last Edit: November 24, 2009, 11:08:31 am by Blanka »
Hoopz
« Reply #6 on: November 24, 2009, 11:23:54 am »
uTorrent will give you a pop up saying that there's not enough room on the HD for the size of the torrent, but you can choose to download it anyway.  If it's a 200gig torrent, yet you only select 1 gig, it'll work without a problem.  The newer versions are much faster/easier in selecting the individual files out of 8,000+ etc too.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #7 on: November 24, 2009, 12:09:51 pm »
Vuze doesn't do that anymore. It might make some of the files if they share a chunk or whatever, but it doesn't require the full download size.
Blanka
« Reply #8 on: November 24, 2009, 03:07:10 pm »
uTorrent runs great. Even on my Atom internet station, selecting in 10000 files is peanuts. uTorrent combines all chunks with other file content in one big temp file which is thrown away after finishing. Excellent!
« Reply #9 on: November 24, 2009, 03:35:04 pm »
+1.  And it does all of those things.  You can configure a different dir for the .part files than the download dir.  Just make sure you keep it on the same physical drive or you're multiplying the amount of work being done by a factor of maybe 3 or 4.
Hoopz
« Reply #10 on: November 24, 2009, 05:57:09 pm »
Glad that worked.  You missed a few versions back where it would take forever to not select all the files and then select just a few.  I'm not bitching about free programs that others do though.  Just observing.   :)
