Author Topic: Street fighter 2 blowing fuse  (Read 2948 times)
joltron
  • Last login:November 27, 2009, 02:54:48 pm
« on: November 24, 2009, 07:31:41 am »
I have ventured around the internet and all I can find for street fighter 2 champion edition is an instruction manual.  Does anyone know of a place that I may find a schematic for it?
I would like to turn it into a mame machine using the original monitor but my current issue is if power is hooked up to the monitor it pops a fuse on the power supply.
If anyone has any advice it would be greatly appreciated.
Ken Layton
  • Guru
  • Technician
Re: Street fighter 2 blowing fuse
« Reply #1 on: November 24, 2009, 10:17:16 am »
This was a conversion kit and could be in just about any cabinet. Need to see pictures of your cabinet.
Be sure to read the sticky:
http://forum.arcadecontrols.com/index.php?topic=62016.0
You'll need to identify the make and model of monitor installed in your cabinet as some monitor faults can cause cabinet fuses to blow.
joltron
« Reply #2 on: November 24, 2009, 10:12:28 pm »
I was at work when I posted earlier so I couldn't get the info.
But so far what I can see is
Monitor board = NANAO KB24033ID
The fuse that blows is a 3amp fuse just after the 120ac incoming.
There is a quick disconnect near the monitor that feeds the 120ac after the switch to the monitor, if this i unplugged the fuse doesn't blow.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: November 24, 2009, 11:04:01 pm »
Monitor is a Sega/Nanao MC-2030-S (a.k.a. Kaga KZ-20ES). May have a sticker on the picture tube saying Sega part # 200-5044.
I _think_ that your cabinet may have been a Kung Fu Master or a Yie Ar Kung Fu judging by the power supply/chassis assembly in the bottom of the cabinet. I don't see how your game board can operate since the power supply is not even plugged in nor bolted down.
joltron
« Reply #4 on: November 24, 2009, 11:11:19 pm »
Unhooked gameboard to see if it was causing the fuse to blow.
Ken Layton
  • Guru
  • Technician
« Reply #5 on: November 25, 2009, 01:05:08 am »
Disconnect the power wires going to the marquee fluorescent light fixture. You could have a shorted ballast causing the fuse to blow.
joltron
« Reply #6 on: November 26, 2009, 08:31:30 pm »
Well I haven't had time to go out and buy new fuses with the holidays and all going on but I'm pretty sure teh balast is fine.  There is a 2 wire quick disconnect going to the monitor board, with that unplugged I don't pop the fuse.  Any idea on what my next step should be?
Ken Layton
  • Guru
  • Technician
« Reply #7 on: November 27, 2009, 12:30:43 am »
Pull the monitor board and start checking for shorted parts.
