Author Topic: Mamewah default exit to windows shortcurt?  (Read 1650 times)
chazbeenhad
  • Last login:July 06, 2010, 02:37:28 pm
« on: November 23, 2009, 09:19:11 pm »
Can someone tell me Mamewah's default exit to windows shortcurt?
Also whats the best way to disable the exit menu option in mamewah? Would it invole editing the layout I'm using?
Sorry for the super noob questions!
chazbeenhad
Re: Mamewah default exit to windows shortcurt?
« Reply #1 on: November 23, 2009, 10:08:53 pm »
Ok, I found out exit to windows shortcut was mapped to the right windows key. No problem, that works well.
So I guess my only question left is how do I disable the Exit option in the menu.
rockmes
  • Last login:June 05, 2016, 09:41:38 am
  • Don't you love it?
« Reply #2 on: November 24, 2009, 04:10:42 am »
check , there should be a file called mamewah.cfg in your config folder of mamewah.
chazbeenhad
« Reply #3 on: November 24, 2009, 08:35:14 am »
Thanks. What I did was make the button I normaly use for the menu selet the next emulator. I bound a different key to the menu dialog. So if I should need the menu for any reason I plug in a USB keyboard and can work it that way. Now the kids cant exit mamewah, something they always seems to do. :)
