Author Topic: Once again ATI Component video question  (Read 2304 times)
tekopaa
  • Last login:March 24, 2012, 11:19:53 am
« on: November 20, 2009, 01:50:46 am »
Want to know  can i use ATI DVI-COMPONENT DONGLE WITH X600 PRO PCIE 256. Basicly its 9600pro in PCI-E bus. Found this old list here . So with these card dongle works??? I know it works 9500,8500,9600,9700,9800 series. Does it work with X series 2 ??  :afro: I have free X600 card here got it free
My card has DVI-I connector its made CONNECT3D
http://img.ncix.com/gif/14343.JPG
RADEON X800 PRO
RADEON X800 XT PLATINUM EDITION
RADEON X300
RADEON X600 PRO
RADEON X800 XT
RADEON 9800 XT
RADEON 9800 PRO 256MB
RADEON 9800 PRO 128MB
RADEON 9800 128MB
RADEON 9600 XT
RADEON 9600 SE
RADEON 9600 PRO 128MB
RADEON 9600 128MB
« Last Edit: November 20, 2009, 01:53:25 am by tekopaa »
RVZ
  • Last login:November 07, 2025, 03:28:50 pm
    • Metal Slug!
Re: Once again ATI Component video question
« Reply #1 on: July 19, 2010, 07:12:52 am »
RADEON X800 PRO
RADEON X300
RADEON X600 PRO
RADEON X800 XT
RADEON 9800 XT
RADEON 9800 128MB
RADEON 9600 XT
RADEON 9600 SE
RADEON 9600 128MB
Will a newer ATI card like the ATI HD3450 also work with the DVI to Component adapter?
computarmann
  • Last login:February 20, 2014, 12:42:46 pm
« Reply #2 on: February 20, 2014, 12:42:46 pm »
I know this is an old post but maybe someone will find this if they have this question. ATI x300, despite all the post to the contrary, will put out component video out the 7 pin din with the breakout cable that has red,blue and green. It is a little tricky to get it working. Here is the trick. You have to have your TV set on component video and the TV has to be on the proper video output in order for catalyst to detect that you have an HDTV. If you just plug it in and boot up, the default will be s-video and it looks really strange coming through the component input on your TV. The next step is to go on display manager and in my case I see 2 televisions listed for the tv. One is for HDTV and one is for SD. Choose the HDTV symbol and drag it into the second window on catalyst and either extend desktop or clone. I would suggest choosing clone. At first you may not get any video because your desktop is probably at a relatively high resolution that the TV is incapable of displaying. Be careful some TV's I read could be damaged from unsupported resolutions. To be safe it would be helpful to choose 640x480 before cloning the desktop onto the TV. If you want to only use the TV in the future it must be set as the primary display and then you can boot up to the TV. Anyway Im using 640x432 whuch catalyst must have detected but it was not in the resolution at first but it has no overscan and all mame works without any size issues and on my Panasonic flat screen even though I do not have scanlines for authenticity everything looks absolutely amazing.
