Author Topic: Is a sttudio monitor like this be good for a MAME monitor ?  (Read 1595 times)
Nataq
  • Last login:October 21, 2023, 09:09:45 am
  • Arcade of the dead... now alive!
« on: November 07, 2009, 07:26:57 am »
I am seeing a 26" SONY TRINITRON KX-2501A monitor for cheap in my local ads. Searching the net a little I think I saw year of construction beeing 1983. Pretty old but apparently a good monitor. I am worying about the connexion though. I only found this page with some information on the third page. The RGB thing is what I think some people use is that right ?
http://safemanuals.com/fullswf-SONY.php?type=00001.JPG&file=SWF/SONY/KX2501A&langue=en&img_width=604&img_height=994&cat=vide
Thank you very much
Jack Burton
Re: Is a sttudio monitor like this be good for a MAME monitor ?
« Reply #1 on: November 07, 2009, 03:16:42 pm »
That monitor has RGB connections on a strange looking connector with a lot of pins.  You will either have to find a connector for sale, make one, or pay a member here to make one.  But I do think you could use this as an arcade monitor.
This monitor should be of very high quality if it is in good shape.  It will be 15khz only.
« Last Edit: November 07, 2009, 03:21:21 pm by Jack Burton »
Ummon
  • Trade Count: (+13)
« Reply #2 on: November 07, 2009, 04:11:27 pm »
- could be tricky finding the pinout for that.
- it's old. Make sure you see it run for at least a half hour.
Yo. Chocolate.
Stephen Hawking
