Author Topic: Screensaver Error  (Read 2678 times)
Milner08
  • Last login:September 05, 2010, 02:58:15 pm
Screensaver Error
« on: November 06, 2009, 01:34:16 pm »
Mala keeps generating this erron while displaying the built in screensaver.
2009/11/06  18:09:17.37   Error: Object Class: TTimer, Object Function: PlaySound, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 02151000
2009/11/06  18:09:17.42   Error: Object Class: TfrmScreensaver, Object Function: PlaySound, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 02151000
This is the latest stable relase, and is being run on XP.
Anyone know what could be causing this? Or know of a way to fix it?
Thanks TM :)
loadman
  • Moderator
  • Last login:Yesterday at 08:32:52 pm
  • MaLa FE developer
    • MaLa
Re: Screensaver Error
« Reply #1 on: November 14, 2009, 09:21:53 pm »
I would try the beta version
Milner08
« Reply #2 on: November 15, 2009, 01:15:04 pm »
Ok, Ive got the beta, Ive set it up in its own folder, with a copy of the base dll from the main install, and a copy of all the programs that the stable release comes with, but im unable to create a tree using malatree :/ It just doesn't recognise the games lists properly.
Is there a new copy of malatree which works with the new gameslists? Or is there a way to create one manually?
TM
