Author Topic: Swapped G07 tube, what's yellow cable for?  (Read 2799 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« on: November 06, 2009, 12:25:54 am »
Got a G07 in a Midway cocktail and I can't get any reds (well, maybe the faintest of dark brown), and the other colors are kind of weak. I tried a different (known working) chassis and the image is the same. I tweak the pots on the neckboard and barely see any difference in anything. I think only the blue showed any effect.
To be sure it wasn't the signal, I hooked up another good monitor to the video output and that one showed a nice bright colorful picture.
So... experts, is it likely a dying tube/guns?
« Last Edit: November 16, 2009, 11:54:38 pm by RayB »
NO MORE!!
SirPeale
  • Green Mountain Man
Re: G07 with no red and weak picture overall
« Reply #1 on: November 06, 2009, 04:56:03 am »
Someone recently described a similar problem.  Check R517.
Kevin Mullins
    • Me on Myspace
« Reply #2 on: November 06, 2009, 11:20:27 am »
But if a known working chassis had the same results, then I'd be checking the tube.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: November 06, 2009, 01:25:14 pm »
Connect the tube to a rejuvenator and test it. Ends any guesswork.
SirPeale
« Reply #4 on: November 06, 2009, 04:28:52 pm »
That'll teach me to skim.  Yeah, hook it to a rejuvenator (if available) and if that fails, replace the tube.
RayB
  • There's my post
    • RayB.com
« Reply #5 on: November 16, 2009, 11:54:05 pm »
As if I'm gonna find a rejuvenator. ;-)
OK so I found another G07 tube and swapped them. Paired it with my "best" chassis (a clean, capped one with new flyback and width coil). Got a nice picture, but the Horizontal width coil adjustment does nothing. Any ideas?
Oh, and I need to know if this flat yellow cable is supposed to be attached to anything (the cabinet had no wires that would appear to attach to that)
NO MORE!!
Ken Layton
  • Guru
  • Technician
Re: Swapped G07 tube, what's yellow cable for?
« Reply #6 on: November 17, 2009, 01:23:50 am »
That's the picture tube ground wire. It plugs into the "E" terminal on the neckboard.
RayB
  • There's my post
    • RayB.com
« Reply #7 on: November 17, 2009, 01:58:33 pm »
What gauge wire should I use?
I don't have this wire on ANY of the 3 G07 chassis in my possession.
NO MORE!!
Kevin Mullins
    • Me on Myspace
« Reply #8 on: November 17, 2009, 02:33:52 pm »
What Kens saying is there is a "pin" that that plugs directly into on the neckboard.
Look for what looks like a test pin marked "E".
Usually a small spade terminal looking pin. (matches the end on the yellow wire)
RayB
  • There's my post
    • RayB.com
« Reply #9 on: November 18, 2009, 04:11:48 pm »
OH. What threw me off is that BOTH tubes had that cable mounted in the plastic cable holders. I thought that's where it went. LOL
NO MORE!!
Kevin Mullins
    • Me on Myspace
« Reply #10 on: November 18, 2009, 04:20:12 pm »
Nah, looks like they just did that to hold it out of the way.
That plastic cable holder on the tube is actually for the big red flyback anode lead.
