Author Topic: Project...um...First Timer!!!!  (Read 14772 times)
kjeffery
  • Last login:May 20, 2016, 03:29:58 pm
« on: November 03, 2009, 05:35:22 pm »
Hows it going all. I just purchased my first cabinet and plan on making a nice mame cabinet with it. Just 2 players with 6 buttons each and frontend all controlled by joystick and buttons, no keyboard or mouse. I just picked this baby up today for a whopping 40$. Cab is in really good shape with no water damage, just usual scratches and knicks.Plan on sanding down, Krilz oil based primer then satin black water based latex main coat and blue t molding.The guy sold it cheap. I put a want add on craigslist and said he had one in his auto repair shop sitting int he back covered up cause the monitor went out. Anyone got a idea what brand cabinet or what original games was in it? The games turns on and I can here it say Time Killers. I would like to fix the monitor for the mean Time until I order my parts so I can play it. Any help is grateful.
So was 40$ a good deal..hehehe.Im in davenport,ia if anyone is near by and can help me. pretty much know how to do everything but would be cool to have a friend help
how it sits now
« Last Edit: November 08, 2009, 06:10:54 pm by kjeffery »
Of all the things I lost, I miss my mind the most!!
Re: Newb here making his first mame.
« Reply #1 on: November 03, 2009, 07:36:46 pm »
$40 is the right price! Looks like its an old Dynamo HS-1.  Could have been a Street Fighter 2 or Final fight at some point, though they were pretty popular so I wouldn't know why they'd want to convert it. Does the sides look painted? When you sand it down  there might be some original art there... any tags inside?
A general rule of thumb is to never mix your oil-based and water-based painting products together. That's just asking for trouble. If you're going with water-based Acrylic Latex, then I'd suggest finding a good Primer to match.
kjeffery
« Reply #2 on: November 03, 2009, 09:00:33 pm »
so should i just use oil based primer and oil based latex satin black? it was repainted , i can see brush marks and some kind of textured paint,almost like bed liner.no markings anywhere
« Reply #3 on: November 04, 2009, 12:39:05 am »
Yup, keep your oils with oils, and waters with waters.
When you sand it down, let's see whats underneath there. Could give you some clues to what it was previously.
DCsegaDH
« Reply #4 on: November 05, 2009, 03:05:47 pm »
That's a strange button layout, I didn't know they came like that. I like Dynamo cabinets, but the only problem I have is the control panel, it seems a little small to me, but other than that its a great cabinet!
kjeffery
« Reply #5 on: November 05, 2009, 04:01:05 pm »
yeah the layout is wierd but ill be changing it to the street fighter layout or similar.another thing i like is there is no carriage bolts for the joysticks .the bolts are welded or something and flush. control panel is big enough for me and my buddy. oh yes, i just scored a free 21inch viewable pc crt monitor for free off craigslist.dang its so cheap to do this.just put want adds on craigslist and get stuff for super cheap. ill be ordering my tmolding, joysticks, pushbuttons and interface monday and getting painting supplies as well and getting the monitor today
« Last Edit: November 05, 2009, 04:05:16 pm by kjeffery »
kjeffery
« Reply #6 on: November 05, 2009, 06:51:42 pm »
looks like the monitor was only a 19...is that too small...i might just use it for now until i can get a bigger one..i want at least 21..but 19 is ok for now
DCsegaDH
« Reply #7 on: November 05, 2009, 07:31:33 pm »
Yeah, IMO the Street Fighter layout is the best choice for most games.
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #8 on: November 05, 2009, 10:06:45 pm »
Easily. If you can hear the Time Killers sounds, chances are the PCB is fine and the monitor was buggered - if you know someone with a JAMMA cab, plug the PCB in to see if it works and sell it. Not a gret game, but has limited novelty value. Most of these cabs I saw as Street Fighter 2 online, so it probably was intended for that and just had the c.p hacked up with bits shoved on for Time Killers.
kjeffery
« Reply #9 on: November 05, 2009, 10:15:23 pm »
Yeah the pcb works and was plan on selling it on here for fairly cheap. Yeah you can tell the control panel was hacked up. Time will tell when i start sanding it and see whats underneath the paint. so is 19 inch fine for this cab..just for the mean time
Turnarcades
    • Turnarcades
« Reply #10 on: November 06, 2009, 10:33:12 am »
Don't forget a 19" CRT PC monitor will only have about a 17.5-18" viewable screen and the rest will be covered up. Depending on the dimensions of the cabinet itself this may or may not look out of place. If I were you I'd hunt for the maximum 21/22" CRT monitor, which will give just under 20" viewable area and look a lot better.
Chicken McNobody
  • I poop too much. . .
« Reply #11 on: November 06, 2009, 11:43:45 am »
My P.O.W. dedicated cab is that same style, and I always thought it was a 17 inch monitor.  But it actually is a 19, so it does feel small for the size of the cab.  I would even see about squeezing a 23-25 incher in there, I think it should handle it.
« Last Edit: November 06, 2009, 12:05:19 pm by Chicken McNobody »
kjeffery
« Reply #12 on: November 06, 2009, 04:15:01 pm »
Yeah I will eventually when I find a good deal but as for now I got the 19 inch in there. I took a crt monitor out fo its case and put it in the old casing for the original and it fits perfect.Ill post pics later cause it was a little more and just plopping it in there. I had to cut wires and extend them and all to make it how i wanted it
kjeffery
« Reply #13 on: November 06, 2009, 06:39:41 pm »
Pics of the monitor mounted. I just used the metal casing from the original arcade monitor and put a crt in there. The screen size is 19 inches like the original and fits pretty good besides the mounting but its very very sturdy and isnt going no where how I did it. I also had to move the crt electronic board down a little for it to fit just right. you can see what wires i cut to extend so i could move it a little because before there was hardly any wire to work with. i also had to cut some wires just to get the tube disconnected from the board and then butt connected them back together and had to ground a couple spots. Works perfect!!! Will show some pics later fo it on. I am picking up a peace of greylite 14 next week so the cardboard bezel in there now will not be visible. By the way that's the stock bezel that cam with just sprayed painted it black cause it was all faded out. I am happy how easy that monitor fitted
here you can see how mounted the electronic board tray for the crt
kjeffery
« Reply #14 on: November 07, 2009, 11:42:14 pm »
Did some sanding tonight. Did half of one side and didn't find any old graphics underneath, looks like it was just an original a black cabinet. Taking for ever to sand using a palm sander and 120 grit. But once it was sanded it is very very smooth almost to smooth to be true, and might only need to hit it when its done  with 300-500 grit and prime it. Ill post pics sometime tomorrow.
kjeffery
« Reply #15 on: November 08, 2009, 04:46:34 pm »
Dang just about killed myself not using a respirator. Finally found my good respirator mask in a box today
kjeffery
« Reply #16 on: November 08, 2009, 05:39:23 pm »
Here is some pics of the sanding process. Going to buy some 80 grit Wednesday to speed up the process then hit it with 120 then 220 to finish it then primer and 2 coats primer sanding with 220 in between then 2 coats of final color. Also going to start bondoing the control panel. Thats not rust just dirty adhesive. whats the cheapest thing o strip it off with and the fastest
Tools of the trade today
Re: Project...um...First Timer!!!!
« Reply #17 on: November 08, 2009, 07:37:59 pm »
Get yourself some Goo-gone. That stuff works great to get that adhesive off, you can find it at any hardware store. Just drench it with Goo-gone then let it sit for a bit, the adhesive will come off with a wipe.
kjeffery
« Reply #18 on: November 08, 2009, 07:45:15 pm »
Im hitting up the home depot tomorrow and getting everything for painting and such and stopping by a glass shop to get my greylite 14. Is 1/8 dark enough enough to hide the bezel and just see the monitor when it comes on?
« Last Edit: November 08, 2009, 07:51:05 pm by kjeffery »
kjeffery
« Reply #19 on: November 10, 2009, 10:41:53 am »
Got everything fully sanded with 80grit last and will be doing 120 grit then a 220 and get it ready for paint. also filled in some holes with bondo. pics to come tonight and hopefully get my control panel stripped and fill in that weird layout.looks like my order from groovy gamer will be here friday if im lucky
mwong168
  • Last login:May 28, 2019, 11:38:54 am
« Reply #20 on: November 10, 2009, 01:22:32 pm »
That is a sweet deal for the cabinet my friend.  I paid more then that just for my coin door without the coin cartridge mechanism and coin box  :banghead:  If you are ever looking for original control panel artwork check out Scott at mamemarquees.com  His work and quality is top notch, my friend has the exact same cabinet restored to SF2:CE
Showcase Project [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=93701.0
Bartop Project [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=98410.0
Custom Wireless 360/PC HAPP Fight Sticks [100% Complete]
http://forum.arcadecontrols.com/index.php?topic=100809.0
Visual Pinball Cabinet [Work in Progress]
http://forum.arcadecontrols.com/index.php?topic=102628.0
kjeffery
« Reply #21 on: November 10, 2009, 04:45:01 pm »
Yeah I plan on ordering my marquee form there
kjeffery
« Reply #22 on: November 10, 2009, 08:42:19 pm »
Updated pics from last night.
DCsegaDH
« Reply #23 on: November 11, 2009, 01:11:58 am »
Nice job sanding! I can't wait for some pictures :applaud:
kjeffery
« Reply #24 on: November 11, 2009, 01:18:40 am »
Got some more done tonight. Started working on the control panel. I using fiber glass on the underside to fill in the holes I dont want then on top Im sanding then putting bondo up top and sand them level and drill new holes and using spray bed liner to put on the control panel, it will be like a rugged texture finish and when I get my plexi cut for it Just the sides and the bottom of the control panel will have then texture cause Im spraying the back side of the plexi black. I also primed the sides and front. I used Kilz which is really thick, it will definitely needed to be sanded due to how thick it goes on.
kjeffery
« Reply #25 on: November 12, 2009, 12:29:58 am »
Got one side painted today and looks ok, I used a foam roller and can see some streaks and little uneven but its only the first coat but Im sure it will look better after 2 more coats. Everything else is ready for paint. I also filled in all the holes on the control panel I didnt need with bondo and is really even and smooth. Ill be drilling new holes tomorrow and maybe painting it with the bed liner. Ill post pics tomorrow of what I got done.
kjeffery
« Reply #26 on: November 14, 2009, 08:15:41 am »
Well it was finally a little warmer yesterday..around 58 degrees and I put on my final coat of paint. I used kilz oil based primer and rustoleum oil based satin black and a smooth foam roller. To anyone doing this and not getting god results, I was not getting good results either but after I sanded it with 500 grit and put on my 3rd coat it was like a whole new paint job. Yes there is imperfections in the paint here and there and might night be professionaly smooth, but it looks hella better than it did before and this was my first time painting stuff like this.Here is the pics along with pics of the progress of the control panel. These are not the buttons Im using just testing them. I still haft to drill the holes for the each of the players 6 buttons. Let me know what you think!!! Just dust in the pics of the cab if you was wondering.
« Last Edit: November 14, 2009, 08:44:57 am by kjeffery »
kjeffery
« Reply #27 on: November 14, 2009, 09:30:34 am »
Well basically its going to be a waiting game now until my wife gives me more funds to buy a computer, speakers and marquee and light. my t-molding,interface, buttons and joysticks should be in next week from groovygamegear.com. this weekend ill probably drill the holes for the buttons and and cut out the plexi for the control panel. I am going with the deep space blue t molding with player one controls being blue and player 2 controls being red. Im getting the mame blast marquee from mamemarquees.com. will post pics of the goodies when i get them. so would a 1.5ghz with 1gb ram good enough to play mk3 and metal slug and such and the street fighters? I have just bought a house and will be closing before thanksgiving so i hope to have this 90% done before i move at the end of this month
« Last Edit: November 14, 2009, 10:19:52 am by kjeffery »
kjeffery
« Reply #28 on: November 14, 2009, 12:33:24 pm »
well just tried to drill the holes for the buttons and i must say hole saws suck. it chewed my bondo and control panel all up, now im redoing the bondo and gonna use a uni bit, which doesn't cut it just scraped the sides making the hole larger and larger. also the drill bit that steadies the saw bent on my first hole. im taking it back to lowes
« Last Edit: November 14, 2009, 12:53:48 pm by kjeffery »
Turnarcades
    • Turnarcades
« Reply #29 on: November 14, 2009, 01:39:50 pm »
Most people will agree that patching a metal panel is very difficult work and especially when it comes to re-drilling, difficult to do. I wouldn't blame your hole saw, I'd say it's just due to the difference in material consistency between filler and cast metal. You've done great clean-up work on the rest of your cab (proud of ya mate), but it may be a better idea to ditch the metal panel and either cut a new one from metal using that as a template, or switch to wood which is much easier to work with and cheaper to reproduce should you cock up.
kjeffery
« Reply #30 on: November 14, 2009, 02:11:10 pm »
Im just gonna cut a rectangle in the metal panel where the buttons need to be and place a piece of plexi over it with the holes drilled like they should, so the plexi would hide the rectangle and the button holes would just be in the plexi and ill support it with another piece of sheet metal underneath it,so it doesn't crack when playing hard, unless the plexi is storing enough to hold the buttons by it self. let me know if you dont get what im talking about
Turnarcades
    • Turnarcades
« Reply #31 on: November 15, 2009, 11:19:05 am »
Unless your plexi is very thick I'd seriously advise against this. Having no kind of bracing directly behind it gives the potential for cracking with the stresses placed on the buttons, particularly with the narrow sections between buttons. Usually, when using plexi it finds strength ang rip by the fact the buttons themselves help clamp the plexi down to the wood backing whilst in use, and add resistance in all directions in terms of tensile strength.
If you really want to stick with metal, you would be best to weld a new plate over the hole, then blend it with 'liquid metal' type filler, not bondo. That way, when you re-drill the bit will bite evenly and create a cleaner hole.
kjeffery
« Reply #32 on: November 15, 2009, 11:42:31 am »
dont have a welder and wont pay anyone to do it. i hacked it up pretty bad last night. im just gonna buy a street fighter control panel for dynamo type cab and use it since everything is cut how i want it besides a couple admin buttons which is no big deal, it might just take me longer to get or find one. see one on ebay for 70$ shipped. looked liked nos, you think it will fit my cabinet it looks the same, unless you have a source for cheaper ones
http://cgi.ebay.com/Dynamo-Black-Arcade-Unpopulated-2plyr-Control-Panel_W0QQitemZ120476214363QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0cf1245b
« Last Edit: November 15, 2009, 11:44:26 am by kjeffery »
Turnarcades
    • Turnarcades
« Reply #33 on: November 15, 2009, 01:35:06 pm »
OK I suppose, but why the hell are the joysticks aligned so high compared to the buttons? For 70 bucks I'd go with making your own
kjeffery
« Reply #34 on: November 15, 2009, 03:21:12 pm »
just found a guy 15 mins from me who is gonna let me go in his warehouse and has couple control panels i want and some glass for the front. he also has a dynamo cabinet with a 26inch he will let me have for 200 working. i dont know what game it is but i might get it after i get done with my mame. ill take pics of the warehouse when i go. i think he control panel hes giving me is from a Nintendo  game but he diDnt say which one. i told him to give em a name or email me a pic. but going into a arcade warehouse IS GOING TO BE SWEET
kjeffery
« Reply #35 on: November 16, 2009, 05:42:50 pm »
look!!!!!!!!!!!1 i just got some of my goodies from groovygamegear.com
ill post some pics form tonight cause im putting the tmolding on
kjeffery
« Reply #36 on: November 16, 2009, 11:51:55 pm »
here are some pics from tonight, im sorry for the dust particles!!! just have that marquee in there until i order a mame themed one
kjeffery
« Reply #37 on: November 17, 2009, 10:30:19 pm »
here is a better pic after dust has settled in garage
kjeffery
« Reply #38 on: November 19, 2009, 08:10:50 pm »
Well picked up my computer today that Im using in here. Its a 1.7ghz amd athlon xp(rated at 2ghz) with 512mb ram and 20gb hd. Will be perfect for street fighter and mortal kombat games. Got this baby ready to go off craigslist for 15$
Ill be removing case panels and putting it in cabinet this weekend
kjeffery
« Reply #39 on: November 20, 2009, 09:20:17 am »
can anyone tell me why this runs so slow? im using mame version .115 and it is just horrible on every game and takes for ever to load. my specs are 1.5ghz athlon xp, 512mb ram and 20gb hd and maybe the integrated 8mb video is a slow down? which version of mame should i use?
