Author Topic: Happs super to ball top conversion  (Read 2853 times)
steve_pss
  • Last login:December 19, 2020, 06:56:53 pm
« on: July 18, 2003, 12:19:29 pm »
Anyone know of a way to convert the shaft and top on my supers to a longer ball top? I noticed some robotron joystick repro's for sale. Anyone try useing them?
OSCAR
    • Oscar Controls
Re:Happs super to ball top conversion
« Reply #1 on: July 18, 2003, 12:44:43 pm »
The Happ supers use a 10mm shaft, and Robotron (WICO) shafts are 3/8" diameter.  I'm not aware of any 10mm shaft balltop handles.
steve_pss
« Reply #2 on: July 18, 2003, 01:01:18 pm »
well thats just downright depressing..
Grasshopper
  • Last login:September 23, 2026, 03:46:37 pm
« Reply #3 on: July 18, 2003, 03:07:21 pm »
This website might cheer you up!
http://members.aol.com/n2new/specialtyplastics.htm
steve_pss
« Reply #4 on: July 18, 2003, 03:47:31 pm »
Sweet. Sent an email for pricing. Do the Super and Comp use the same shaft length and width?
Grasshopper
« Reply #5 on: July 18, 2003, 04:08:29 pm »
I haven't tried it myself. However according to previous threads on this board, the Competition and Super handles are indeed interchangeable.
OSCAR
    • Oscar Controls
« Reply #6 on: July 18, 2003, 04:14:23 pm »
Dang, I always forget about that guy.  I didn't know he had a website, though, I thought he was strictly eBay.
I haven't tried swapping the Comp & Super handles in quite a while, but IIRC there was something funky about the actuator on the Comp that caused the e-clips not to line up, or something like that.  I do know that the Comp & Super have different length shafts, but there was something about the e-clips...  Maybe it just needed a different sized spacer...  Hmmm, if I get a few momemnts this evening, I'll check that out again because now I'm curious.
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #7 on: July 18, 2003, 04:21:09 pm »
Great! whenever OSCAR "gets curious" we end up finding there's somethign ELSE we need to buy =P
rampy
Hoagie_one
  • Um....whats a cabinet
« Reply #8 on: July 18, 2003, 04:30:20 pm »
always another adapter
always another switch
always another dollar
sigh
OSCAR
    • Oscar Controls
« Reply #9 on: July 18, 2003, 04:37:44 pm »
rampy
Oh come on, its not that bad, is it?  That's the fun part, I thought, to keep dinking around with the cabinets & controls.  Who actually plays theirs?  Last I checked, I had MAME .24 on mine... ;)
OSCAR
    • Oscar Controls
« Reply #10 on: July 18, 2003, 11:42:28 pm »
It seems that the standard Comp handle is too short to use in a Super base.  I don't know if n2new's Comp handles are longer with extra retaining ring grooves, but if not, then it doesn't look good.
Both handles, side-by-side:
The Super conical bushing installed on the Comp.  Note that the Comp bushing is very close in height, so either one will be about the same:
The grooves are right where the actuator is going to be installed:
Too short!
Grasshopper
« Reply #11 on: July 19, 2003, 07:40:22 am »
I've found one of the original threads on this topic.
http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=191;start=msg1182#msg1182
It appears that you can fit a Super handle to a Competition but not necessarily vice versa. However it should be possible to get Tom to add a couple of extra grooves to his handles.
Also it occurs to me that you could replace the Competition spacer (the one just below the bat handle) with a short Super spacer.
steve_pss
« Reply #12 on: July 21, 2003, 10:28:29 am »
If anyone's interested here is the reply I got:
They fit competition units, They are 10 each. if you order 6 or more they are 8.50 each.
I make them to order.  Personnaly I think the super unit is a piece of junk. The competition unit is a much smoother unit and better built.  If you want some to fit the super I can do a custom job, but you would need to order 4 or more.   These are made to order, I need to recive payment before I make them, takes about a week.
Tom
To bad the super is in such low regard to Tom. His work looks great but I just don't need 4 of them.. tempting tho...tempting...
Chris
    • Chris's MAME Cabinet
« Reply #13 on: July 22, 2003, 02:01:46 pm »
I'm sure you can find someone to go in on them with you... I would, but I just picked up a balltop off eBay....
--Chris
